Voices
Don Jackson
Don Jackson's Posts
Beachside Storage Shed
Forget the 5,000-square-foot beach house just out of sight in the photos. Read more
Posted on:
A Master at Work A Master at Work
Watching from a distance as Fred Sprinkle quickly set pilings with his excavator, I had the impression he was handling much smaller sticks of wood. Read more
Posted on:
After Katrina: One Year Later After Katrina: One Year Later
A year after Katrina: voices and impressions from a region rethinking how to build Read more
Posted on:
Weep Holes in Brick and Stone Veneer Weep Holes in Brick and Stone Veneer
Are weep holes in a typical wood-frame brick-veneer home required anywhere other than at the bottom? What about over and under windows? Read more
Posted on:
Reducing Clearance to Woodstove Pipe Reducing Clearance to Woodstove Pipe
Q. Can I use type X "fire code" gypsum board to reduce clearances to combustibles for a woodstove pipe? For example, could I attach a layer or two of gypsum board to the side or bottom of a nearby cabinet to reduce the required 18-inch clearance? Read more
Posted on:
JLC Field Guide
