Launch Slideshow
Delta Vent SA Review - Peel
  • http://www.jlconline.com/Images/2037818497_delta-1_tcm96-2115502.jpg?width=333
    true
    333
    It's not hard to prime, but it does take some time. Be sure to build this into your costs.
  • http://www.jlconline.com/Images/2110745183_delta-2_tcm96-2115503.jpg
    true
    600
    With a roller screen in a 5 gallon pail the priming goes quickly.
  • http://www.jlconline.com/Images/1478693043_delta-3_tcm96-2115504.jpg
    true
    600
    Delta Vent SA from Cosella-Dorken. This is a fully adhered housewrap so no staples visible here.
  • http://www.jlconline.com/Images/444069889_delta-4_tcm96-2115505.jpg
    true
    600
    I like Quickflash boots for my penetrations. Here's an AC line set. I used the tape that works with Delta Vent SA called Multi Band.
  • http://www.jlconline.com/Images/67241762_delta-5_tcm96-2115506.jpg
    true
    600
    My Andersen 100 Series windows are looking good with this black house wrap!
  • http://www.jlconline.com/Images/81710279_delta-6_tcm96-2115507.jpg
    true
    600
    This is a concrete slab foundation so I used my usual Carlisle CCW 705 at the concrete to sill plate connection for both air and water barrier.
  • http://www.jlconline.com/Images/932255826_delta-7_tcm96-2115508.jpg
    true
    600
    The house is mainly stucco and I'll be using Delta Dry Stucco & Stone for a rain screen on top of the Delta Vent SA.
  • http://www.jlconline.com/Images/967660916_delta-8_tcm96-2115509.jpg
    true
    600
    Anywhere we had Flexx Band we would overlap it with Multi Band tape. Over window heads primarily.
  • http://www.jlconline.com/Images/1612233180_delta-9_tcm96-2115510.jpg
    true
    600
    Delta MULTI BAND is amazing tape that sticks perfectly to Delta Vent SA and to our Plywood substrate at window prep.
I have a feeling that many builders across the US will start to struggle this year with air tightness as the blower door requirement in the 2012 IECC has gotten more stringent. I'm building houses to a tighter standard than code, but frankly I'm struggling too. I really want to build all my houses to a 1 ACH50 (aka "freakin' tight") on the blower door test and it ain't easy! I've come to realize that I need a good air barrier in the same place as my water barrier. Enter Delta Vent SA....
I first learned about Cosella-Dorken (who makes Delta Vent SA) at Joe Lstiburek's Building Science Summer 2013 Camp. I've seen some advertisements for sticky house wraps, but I hadn't really had a chance to explore them. After getting a sales pitch at BS Camp, I was super impressed and wanted to try this on a house. I'll also be installing their rain screen product for Stucco called Delta Dry Stucco & Stone.
The photos below are of an install my crew did this past fall. It's really my first full peel & stick house. I thought it would be super lumpy but overall my crew did an awesome job. It's a nice black uniform tight shirt on this house. The first step is to prep all your window openings. See this video for how we prepped the windows. Remember that this is an air-tight assembly detail so the window install takes some time.
After the windows are prepped we used a primer on the plywood. The primer needs to be tacky before installing the Delta Vent SA, but that only took about 20-30 minutes in our 60 degree weather.
After the primer is tacky you're ready to install the rolls of Delta Vent SA. One tricky issue we found is that the RO for windows needs to be a bit more than our typical 1/4" on all sides of the window. I would allow 3/8" to be safer. The Delta Vent SA material is thick (almost like a fabric), and the plastic corners on the windows add depth too.
In summary, I've really liked this Delta Vent SA product. I may be hard to find in your area, but if you're looking to ratchet down your air tightness and have a high perm house wrap this product is fantastic.
To read this original article click here. Be sure to check out my video blog on YouTube.
