<rss version="2.0" xmlns:hwi="http://www.hanleywood.com" xmlns:tcm="http://www.tridion.com/ContentManager/5.0" xmlns:tcmse="http://www.tridion.com/ContentManager/5.1/TcmScriptAssistant" xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:tcl="urn:TridionComponentLink"><channel><title>Journal of Light Construction: Air Conditioning</title><link>http://www.jlconline.com/building/hvac/air-conditioning/default.aspx?view=rss&amp;id=Query_tcm961221844</link><image><title /><url /><link /></image><description>
        The number one best practices resource for builders and remodelers
      </description><language>en-us</language><copyright>&amp;copy;2013 Hanleywood</copyright><pubDate>Mon, 13 Aug 2012 11:15:22 EST
	</pubDate><webMaster /><item><title>Ductless Heat Pumps</title><link>http://www.jlconline.com/hvac/ductless-heat-pumps.aspx?rssLink=Ductless+Heat+Pumps</link><description>
              &lt;a href=http://www.jlconline.com/hvac/ductless-heat-pumps.aspx?rssLink=Ductless+Heat+Pumps &gt;
              &lt;img src=/Images/tmp451C%2Etmp_tcm96-1454301.jpg width=90 height=72 alt=0712_jlc_ductless_00.jpg(90) title=0712_jlc_ductless_00.jpg(90) /&gt;&lt;/a&gt;
            These easily installed units offer flexible sizing and high efficiency at moderate cost.</description><pubDate>Mon, 13 Aug 2012 11:15:22 EST
      </pubDate><category>HVAC</category><category>Heating</category><category>Green Building</category></item><item><title>Programmable Thermostat</title><link>http://www.jlconline.com/green-products/programmable-thermostat.aspx?rssLink=Programmable+Thermostat</link><description>
              &lt;a href=http://www.jlconline.com/green-products/programmable-thermostat.aspx?rssLink=Programmable+Thermostat &gt;
              &lt;img src=/Images/T1900%20Slimline%20Residential%20high%20res_tcm96-940945.jpg width=90 height=79 alt=T1900 Slimline Residential high res(90) title=T1900 Slimline Residential high res(90) /&gt;&lt;/a&gt;
            The Slimline Platinum thermostat provides control of both temperature and humidity levels.</description><pubDate>Wed, 16 Jan 2013 10:30:10 EST
      </pubDate><category>Green Products</category><category>Appliances</category><category>HVAC</category></item><item><title>Soundproofing Outdoor Generators and Condensers</title><link>http://www.jlconline.com/acoustics/soundproofing-condensers-and-generators.aspx?rssLink=Soundproofing+Outdoor+Generators+and+Condensers</link><description>
              &lt;a href=http://www.jlconline.com/acoustics/soundproofing-condensers-and-generators.aspx?rssLink=Soundproofing+Outdoor+Generators+and+Condensers &gt;
              &lt;img src=/Images/tmp497%2Etmp_tcm96-1072872.jpeg width=90 height=52 alt=jlc1110sch_lead_fmt.jpeg(90) title=jlc1110sch_lead_fmt.jpeg(90) /&gt;&lt;/a&gt;
            Special mounts, acoustic blankets, and properly sized barriers are all part of the solution.</description><pubDate>Tue, 12 Jun 2012 04:33:28 EST
      </pubDate><category>Acoustics</category><category>HVAC</category></item><item><title>Staff Report: Blackout Power Solutions</title><link>http://www.jlconline.com/coastal-contractor/staff-report-blackout-power-solutions.aspx?rssLink=Staff+Report%3a+Blackout+Power+Solutions</link><description>
              &lt;a href=http://www.jlconline.com/coastal-contractor/staff-report-blackout-power-solutions.aspx?rssLink=Staff+Report%3a+Blackout+Power+Solutions &gt;
              &lt;img src=/Images/tmp3B8%2Etmp_tcm96-1393419.jpg width=90 height=56 alt=coa0907eg_lead.jpg(90) title=coa0907eg_lead.jpg(90) /&gt;&lt;/a&gt;
            The small, gasoline-powered portable generator is the classic ad hoc response to a major power outage. Yet it may be the homeowner's worst possible choice. Able to provide only enough output for a few lights and a refrigerator, gas-powered generators need frequent refueling and make a lot of noise. Of even more concern is the fact that in a storm situation, portable generators often kill a few people, either by carbon monoxide poisoning or by electrocution. What's more, gasoline spills occasionally cause structure fires and serious burns, and if the do-it-yourself user decides to get creative and wire the generator directly into a home circuit, a generator set can "back-feed" the utility, sending lethal voltage to utility workers repairing lines. Our Staff Report looks at the available alternatives to portable generators and guides you in selecting the right size, switch, and wiring options for your needs.</description><pubDate>Tue, 4 Dec 2012 04:08:42 EST
      </pubDate><category>HVAC</category><category>Power Management</category><category>Residential Projects</category><category>Control Systems</category></item><item><title>Products</title><link>http://www.jlconline.com/control-systems/products.aspx?rssLink=Products</link><description>
              &lt;a href=http://www.jlconline.com/control-systems/products.aspx?rssLink=Products &gt;
              &lt;img src=/Images/tmp734%2Etmp_tcm96-1111170.jpg width=90 height=102 alt=0505pr_iko1.jpg(90) title=0505pr_iko1.jpg(90) /&gt;&lt;/a&gt;
            Asphalt shingles; heating and cooling equipment; home automation</description><pubDate>Thu, 14 Jun 2012 12:44:54 EST
      </pubDate><category>Control Systems</category><category>HVAC</category><category>Home Automation</category><category>Roofing</category><category>Rooftop Accessories</category><category>Residential Projects</category><category>Paving</category><category>Roads and Highways</category></item><item><title>Air Conditioning for Humid Climates</title><link>http://www.jlconline.com/hvac/air-conditioning-for-humid-climates.aspx?rssLink=Air+Conditioning+for+Humid+Climates</link><description>
              &lt;a href=http://www.jlconline.com/hvac/air-conditioning-for-humid-climates.aspx?rssLink=Air+Conditioning+for+Humid+Climates &gt;
              &lt;img src=/Images/tmp1C0%2Etmp_tcm96-1105628.jpg width=90 height=133 alt=1004ak-lead.jpg(90) title=1004ak-lead.jpg(90) /&gt;&lt;/a&gt;
            Balancing cooling with humidity control is a tough job in the coastal South. A North Carolina hvac pro explains how the latest generation of cooling equipment meets the challenge.</description><pubDate>Thu, 14 Jun 2012 12:38:50 EST
      </pubDate><category>HVAC</category><category>Energy Efficiency</category><category>Zoning</category><category>Geothermal Systems</category><category>Water Heaters</category><category>Control Systems</category><category>Moisture Barriers</category><category>Residential Projects</category></item></channel></rss>
