<rss version="2.0" xmlns:hwi="http://www.hanleywood.com" xmlns:tcm="http://www.tridion.com/ContentManager/5.0" xmlns:tcmse="http://www.tridion.com/ContentManager/5.1/TcmScriptAssistant" xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:tcl="urn:TridionComponentLink"><channel><title>Journal of Light Construction: Forced Air</title><link>http://www.jlconline.com/building/hvac/heating/forced-air.aspx?view=rss&amp;id=Query_tcm961226695</link><image><title /><url /><link /></image><description>
        The number one best practices resource for builders and remodelers
      </description><language>en-us</language><copyright>&amp;copy;2013 Hanleywood</copyright><pubDate>Tue, 15 Jan 2013 05:51:41 EST
	</pubDate><webMaster /><item><title>Learning Thermostat </title><link>http://www.jlconline.com/green-products/learning-thermostat-from-nest-labs.aspx?rssLink=Learning+Thermostat+from+Nest+Labs</link><description>
              &lt;a href=http://www.jlconline.com/green-products/learning-thermostat-from-nest-labs.aspx?rssLink=Learning+Thermostat+from+Nest+Labs &gt;
              &lt;img src=/Images/tmp159F%2Etmp_tcm96-1031973.jpg width=90 height=67 alt=0112d_EH_Nest_8.jpg(90) title=0112d_EH_Nest_8.jpg(90) /&gt;&lt;/a&gt;
            Nest Labs. The Nest Learning Thermostat monitors homeowner behaviors and preferences to create a customized heating and cooling schedule.</description><pubDate>Tue, 15 Jan 2013 05:51:41 EST
      </pubDate><category>Green Products</category></item><item><title>Cordless Jobsite Forced-Air Heater</title><link>http://www.jlconline.com/tools-and-equipment/mr-heater-battery-operated-propane-jobsite-heater.aspx?rssLink=Mr.+Heater+Battery-Operated+Heater</link><description>
              &lt;a href=http://www.jlconline.com/tools-and-equipment/mr-heater-battery-operated-propane-jobsite-heater.aspx?rssLink=Mr.+Heater+Battery-Operated+Heater &gt;
              &lt;img src=/Images/tmp12E%2Etmp_tcm96-1203961.jpeg width=90 height=74 alt=jlc0112pro_Mrh_fmt.jpeg(90) title=jlc0112pro_Mrh_fmt.jpeg(90) /&gt;&lt;/a&gt;
            Warm up to 800 square feet for up to 12 hours with this portable propane unit.</description><pubDate>Tue, 10 Jul 2012 04:07:56 EST
      </pubDate><category>Tools and Equipment</category><category>Tools and Equipment</category><category>Forced-Air</category></item><item><title>Ductwork That Works</title><link>http://www.jlconline.com/coastal-contractor/ductwork-that-works.aspx?rssLink=Ductwork+That+Works</link><description>
              &lt;a href=http://www.jlconline.com/coastal-contractor/ductwork-that-works.aspx?rssLink=Ductwork+That+Works &gt;
              &lt;img src=/Images/tmp46D%2Etmp_tcm96-1394448.jpg width=90 height=103 alt=coa0508cu_lead-eps10.jpg(90) title=coa0508cu_lead-eps10.jpg(90) /&gt;&lt;/a&gt;
            Air distribution is the weak link in many heating and cooling systems. Good ductwork is key to HVAC performance, yet all too often this vital part of the system is underexamined, bringing the energy performance of the home to surprising lows. Ted Cushman describes how the industry pros detail their ductwork for results you can take to the bank.</description><pubDate>Tue, 4 Dec 2012 04:16:50 EST
      </pubDate><category>Forced-Air</category><category>HVAC</category><category>Building Performance</category><category>Heating</category><category>Building Performance</category><category>Insulation</category></item><item><title>Air Leaks: Hidden Moisture Movers</title><link>http://www.jlconline.com/coastal-contractor/air-leaks-hidden-moisture-movers.aspx?rssLink=Air+Leaks%3a+Hidden+Moisture+Movers</link><description>
              &lt;a href=http://www.jlconline.com/coastal-contractor/air-leaks-hidden-moisture-movers.aspx?rssLink=Air+Leaks%3a+Hidden+Moisture+Movers &gt;
              &lt;img src=/Images/tmp2F1%2Etmp_tcm96-1393055.jpg width=90 height=68 alt=coaj0707ea_lead.jpg(90) title=coaj0707ea_lead.jpg(90) /&gt;&lt;/a&gt;
            Along the coast where wind-blown rain is a regular weather feature, it's no surprise to builders that the exterior of a home must be carefully detailed to manage water. Properly installed housewrap and flashing are the key elements of an effective water-resistive barrier. But rainwater is not the only moisture source, explains building-science consultant Steve Easley. The air itself, particularly the humid air associated with coastal regions, carries a significant moisture load as well. This means that sealing up air leaks is a vital step to managing moisture.</description><pubDate>Tue, 4 Dec 2012 04:04:56 EST
      </pubDate><category>Moisture Barriers</category><category>Insulation</category><category>Exteriors</category><category>Walls</category><category>Building Materials</category><category>Forced-Air</category><category>HVAC</category><category>Windows</category><category>Water</category></item><item><title>Rebuilding the Gulf: Cooling Strategies for the Gulf Coast</title><link>http://www.jlconline.com/coastal-contractor/rebuilding-the-gulf-cooling-strategies-for-the-gu.aspx?rssLink=Rebuilding+the+Gulf%3a+Cooling+Strategies+for+the+Gulf+Coast</link><description>
              &lt;a href=http://www.jlconline.com/coastal-contractor/rebuilding-the-gulf-cooling-strategies-for-the-gu.aspx?rssLink=Rebuilding+the+Gulf%3a+Cooling+Strategies+for+the+Gulf+Coast &gt;
              &lt;img src=/Images/tmp193%2Etmp_tcm96-1391007.jpg width=90 height=88 alt=coamay06co_leadNEW.jpg(90) title=coamay06co_leadNEW.jpg(90) /&gt;&lt;/a&gt;
            In the hot, humid South, it's not enough to install high-efficiency air conditioning. Dedicated dehumidification, along with impeccable attention to sealing the building enclosure, is required. Researchers at LSU exhibit three practical systems that balance performance and cost in the "LaHouse" project -- Louisiana State University's comprehensive demonstration home built to teach Gulf Coast residents and builders sustainable housing solutions.</description><pubDate>Tue, 4 Dec 2012 04:00:15 EST
      </pubDate><category>HVAC</category><category>Ventilation</category><category>Forced-Air</category><category>Water Heaters</category></item><item><title>Air Conditioning for Humid Climates</title><link>http://www.jlconline.com/hvac/air-conditioning-for-humid-climates.aspx?rssLink=Air+Conditioning+for+Humid+Climates</link><description>
              &lt;a href=http://www.jlconline.com/hvac/air-conditioning-for-humid-climates.aspx?rssLink=Air+Conditioning+for+Humid+Climates &gt;
              &lt;img src=/Images/tmp1C0%2Etmp_tcm96-1105628.jpg width=90 height=133 alt=1004ak-lead.jpg(90) title=1004ak-lead.jpg(90) /&gt;&lt;/a&gt;
            Balancing cooling with humidity control is a tough job in the coastal South. A North Carolina hvac pro explains how the latest generation of cooling equipment meets the challenge.</description><pubDate>Thu, 14 Jun 2012 12:38:50 EST
      </pubDate><category>HVAC</category><category>Energy Efficiency</category><category>Zoning</category><category>Geothermal Systems</category><category>Water Heaters</category><category>Control Systems</category><category>Moisture Barriers</category><category>Residential Projects</category></item><item><title>Installing High-Velocity HVAC</title><link>http://www.jlconline.com/hvac/installing-high-velocity-hvac.aspx?rssLink=Installing+High-Velocity+HVAC</link><description>
              &lt;a href=http://www.jlconline.com/hvac/installing-high-velocity-hvac.aspx?rssLink=Installing+High-Velocity+HVAC &gt;
              &lt;img src=/Images/4593222_0307_Install_Hig-Veloc_HERO_tcm96-1248336.jpg width=90 height=60 alt=0307_Install_Hig-Veloc_HERO(90) title=0307_Install_Hig-Veloc_HERO(90) /&gt;&lt;/a&gt;
            Streamlined ductwork, flexible vent placement, and efficient year-round performance make a strong case for high-velocity HVAC, says this veteran installer.</description><pubDate>Thu, 28 Jun 2012 06:40:26 EST
      </pubDate><category>HVAC</category><category>Energy Efficiency</category><category>Indoor Air Quality</category><category>Insulation</category><category>Radiant Floors</category></item><item><title>Pressure-Testing Ductwork</title><link>http://www.jlconline.com/hvac/pressure-testing-ductwork.aspx?rssLink=Pressure-Testing+Ductwork</link><description>
              &lt;a href=http://www.jlconline.com/hvac/pressure-testing-ductwork.aspx?rssLink=Pressure-Testing+Ductwork &gt;
              &lt;img src=/Images/tmp9FA%2Etmp_tcm96-1092643.JPG width=90 height=111 alt=0403un1.JPG(90) title=0403un1.JPG(90) /&gt;&lt;/a&gt;
            Everyone talks about the importance of sealed ductwork, but the only way to be sure a new system measures up is to test it.</description><pubDate>Thu, 14 Jun 2012 12:26:00 EST
      </pubDate><category>HVAC</category><category>Energy Efficiency</category><category>Mechanical Systems</category><category>Ventilation</category><category>Testing</category><category>Insulation</category><category>Residential Projects</category></item><item><title>Q&amp;A: Keeping Attics Cool</title><link>http://www.jlconline.com/zoning/q-a--keeping-attics-cool.aspx?rssLink=Q%26A%3a+Keeping+Attics+Cool</link><description>Q. A two-story house I'm working on has a zoned air-conditioning system with ductwork running through the hot attic, and the A/C can't keep the upstairs zone cool on hot, sunny days. What's the best way to cool that attic space down -- add gable vents to the existing soffit and ridge vents setup, insulate between the rafters, or apply a radiant barrier foil under the rafters?</description><pubDate>Thu, 14 Jun 2012 11:51:34 EST
      </pubDate><category>Zoning</category><category>Mergers and Acquisitions</category><category>Rooftop Accessories</category><category>HVAC</category><category>Insulation</category></item><item><title>Focus On Energy: Shedding Light on Radiant Heat</title><link>http://www.jlconline.com/hvac/focus-on-energy--shedding-light-on-radiant-heat.aspx?rssLink=Focus+On+Energy%3a+Shedding+Light+on+Radiant+Heat</link><description>
              &lt;a href=http://www.jlconline.com/hvac/focus-on-energy--shedding-light-on-radiant-heat.aspx?rssLink=Focus+On+Energy%3a+Shedding+Light+on+Radiant+Heat &gt;
              &lt;img src=/Images/tmp801%2Etmp_tcm96-1089156.jpg width=90 height=85 alt=1002FOE100jlc.jpg(90) title=1002FOE100jlc.jpg(90) /&gt;&lt;/a&gt;
            Shedding light on radiant heat</description><pubDate>Thu, 14 Jun 2012 12:22:58 EST
      </pubDate><category>HVAC</category><category>Radiant Floors</category><category>Slab</category><category>Solar Heating</category><category>Water Heaters</category><category>Flooring</category><category>Insulation</category></item><item><title>Manufactured Fireplaces</title><link>http://www.jlconline.com/fireplaces/manufactured-fireplaces.aspx?rssLink=Manufactured+Fireplaces</link><description>Manufactured fireplaces require no foundation or special framing, and most can be installed in a day. This article explains the available options and how to choose a high-quality product.</description><pubDate>Thu, 14 Jun 2012 12:21:40 EST
      </pubDate><category>Fireplaces</category><category>HVAC</category><category>Metal</category><category>Modular Building</category><category>Indoor Air Quality</category><category>Cost-Effective Design</category><category>Sales Closing</category></item><item><title>Kitchen &amp; Bath: Venting Professional-Style Kitchen Ranges</title><link>http://www.jlconline.com/appliances/kitchen---bath--venting-professional-style-kitchen-ranges.aspx?rssLink=Kitchen+%26+Bath%3a+Venting+Professional-Style+Kitchen+Ranges</link><description>Venting professional-style kitchen ranges</description><pubDate>Thu, 14 Jun 2012 12:17:36 EST
      </pubDate><category>Appliances</category><category>HVAC</category><category>Ventilation</category><category>Kitchen</category><category>Natural Ventilation</category><category>Exhaust Fans</category></item><item><title>Designing &amp; Testing Forced-Air Systems</title><link>http://www.jlconline.com/hvac/designing---testing-forced-air-systems.aspx?rssLink=Designing+%26+Testing+Forced-Air+Systems</link><description>Here are steps you can take to ensure proper sizing and installation of air-conditioning and forced-air heating. Included is a list of detailed specifications that will guarantee state-of-the-art performance.</description><pubDate>Thu, 14 Jun 2012 12:16:46 EST
      </pubDate><category>HVAC</category><category>Specifications</category><category>Energy Efficiency</category><category>Water Heaters</category><category>Mechanical Systems</category><category>Building Performance</category><category>Installation</category><category>Performance Metrics</category></item><item><title>Fine-Tuning Forced-Hot Air</title><link>http://www.jlconline.com/energy-efficiency/fine-tuning-forced-hot-air.aspx?rssLink=Fine-Tuning+Forced-Hot+Air</link><description>
              &lt;a href=http://www.jlconline.com/energy-efficiency/fine-tuning-forced-hot-air.aspx?rssLink=Fine-Tuning+Forced-Hot+Air &gt;
              &lt;img src=/Images/tmpD7%2Etmp_tcm96-1083853.jpg width=90 height=90 alt=1200do1.jpg(90) title=1200do1.jpg(90) /&gt;&lt;/a&gt;
            A heating contractor details how to upgrade from a typical bare-bones heating system to one that delivers comfort and customer satisfaction.</description><pubDate>Thu, 14 Jun 2012 12:12:43 EST
      </pubDate><category>Energy Efficiency</category><category>HVAC</category><category>Water Heaters</category><category>Zoning</category><category>Heat-Recovery Systems</category><category>Geothermal Systems</category><category>Joints</category></item><item><title>Choosing a Whole-House Ventilation System</title><link>http://www.jlconline.com/energy-efficiency/choosing-a-whole-house-ventilation-system.aspx?rssLink=Choosing+a+Whole-House+Ventilation+System</link><description>Homeowners and code officials are beginning to insist on better mechanical ventilation systems. A ventilation expert helps you choose the best system for your climate.</description><pubDate>Thu, 14 Jun 2012 12:11:35 EST
      </pubDate><category>Energy Efficiency</category><category>Exhaust Fans</category><category>HVAC</category><category>Heat-Recovery Systems</category><category>Mechanical Systems</category><category>Building Performance</category><category>Cost-Effective Design</category><category>Distributors</category></item><item><title>Best-Practice Energy Upgrades</title><link>http://www.jlconline.com/basement/best-practice-energy-upgrades.aspx?rssLink=Best-Practice+Energy+Upgrades</link><description>Here are five cost-effective ways to cut energy costs in new construction and remodels.</description><pubDate>Thu, 14 Jun 2012 12:08:59 EST
      </pubDate><category>Basement</category><category>Energy Efficiency</category><category>HVAC</category><category>Insulation</category><category>Foundation</category></item><item><title>Installing Direct-Vent Space Heaters</title><link>http://www.jlconline.com/hvac/installing-direct-vent-space-heaters.aspx?rssLink=Installing+Direct-Vent+Space+Heaters</link><description>Proper installation of these fan-assisted units can provide comfortable, energy-efficient heat in room additions and small dwellings.</description><pubDate>Thu, 14 Jun 2012 12:08:32 EST
      </pubDate><category>HVAC</category><category>Water Heaters</category><category>Energy Efficiency</category><category>Installation</category><category>Small Projects</category><category>Metal</category></item><item><title>Makeup Air For Combustion Equipment</title><link>http://www.jlconline.com/hvac/makeup-air-for-combustion-equipment.aspx?rssLink=Makeup+Air+For+Combustion+Equipment</link><description>
              &lt;a href=http://www.jlconline.com/hvac/makeup-air-for-combustion-equipment.aspx?rssLink=Makeup+Air+For+Combustion+Equipment &gt;
              &lt;img src=/Images/tmp3DE%2Etmp_tcm96-1158383.jpg width=90 height=84 alt=image_lead.jpg(90) title=image_lead.jpg(90) /&gt;&lt;/a&gt;
            Fuel-burning appliances like water heaters, furnaces, and boilers need a steady supply of combustion air to operate safely and efficiently. In today’s tight houses, this means you may have to install dedicated air intakes. In this article, a venting specialist tells you what you need to know.</description><pubDate>Mon, 4 Jun 2012 05:12:30 EST
      </pubDate><category>HVAC</category><category>Water Heaters</category><category>Heat-Recovery Systems</category><category>Rooftop Accessories</category><category>Fire Safety</category><category>Natural Ventilation</category><category>Installation</category><category>Forced-Air</category><category>Heating</category></item><item><title>A Builder's Guide to Geothermal Heat Pumps</title><link>http://www.jlconline.com/energy-efficiency/a-builder-s-guide-to-geothermal-heat-pumps.aspx?rssLink=A+Builder%27s+Guide+to+Geothermal+Heat+Pumps</link><description>Installed correctly, ground-source heat pumps can provide comfortable, efficient heating in many climates. Here’s an overview of the available options.</description><pubDate>Tue, 12 Jun 2012 05:40:42 EST
      </pubDate><category>Energy Efficiency</category><category>Geothermal Systems</category><category>HVAC</category><category>Water Heaters</category><category>Water Conservation</category><category>Installation</category><category>Testing</category><category>Bleeding</category><category>Cost-Effective Design</category><category>Forced-Air</category><category>Heating</category><category>Hydronics</category></item><item><title>Successful Fireplaces in Tight Houses</title><link>http://www.jlconline.com/fire-safety/successful-fireplaces-in-tight-houses.aspx?rssLink=Successful+Fireplaces+in+Tight+Houses</link><description>
              &lt;a href=http://www.jlconline.com/fire-safety/successful-fireplaces-in-tight-houses.aspx?rssLink=Successful+Fireplaces+in+Tight+Houses &gt;
              &lt;img src=/Images/tmp2F2%2Etmp_tcm96-1157285.jpg width=90 height=72 alt=firele.jpg(90) title=firele.jpg(90) /&gt;&lt;/a&gt;
            Want to keep the fireplace from smoking your clients out of their living room? The answer lies in building a straight flue, locating the chimney in the center of the house, and controlling air pressure with makeup air.</description><pubDate>Mon, 4 Jun 2012 04:33:57 EST
      </pubDate><category>Fire Safety</category><category>Fireplaces</category><category>Modular Building</category><category>HVAC</category><category>Living Room</category><category>Building Science</category><category>Codes and Standards</category><category>High-Performance Building</category><category>Interiors</category><category>Lead-Safe Practices</category><category>Small Projects</category><category>Building Codes</category><category>In-House Design</category><category>Forced-Air</category><category>Heating</category></item></channel></rss>
