<rss version="2.0" xmlns:hwi="http://www.hanleywood.com" xmlns:tcm="http://www.tridion.com/ContentManager/5.0" xmlns:tcmse="http://www.tridion.com/ContentManager/5.1/TcmScriptAssistant" xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:tcl="urn:TridionComponentLink"><channel><title>Journal of Light Construction: Service</title><link>http://www.jlconline.com/building/plumbing-electrical/electrical/service.aspx?page=3&amp;view=rss&amp;id=Query_tcm961220656</link><image><title /><url /><link /></image><description>
        The number one best practices resource for builders and remodelers
      </description><language>en-us</language><copyright>&amp;copy;2013 Hanleywood</copyright><pubDate>Fri, 6 Jul 2012 04:04:49 EST
	</pubDate><webMaster /><item><title>Simpler Solar</title><link>http://www.jlconline.com/photovoltaics/simpler-solar.aspx?rssLink=Simpler+Solar</link><description>
              &lt;a href=http://www.jlconline.com/photovoltaics/simpler-solar.aspx?rssLink=Simpler+Solar &gt;
              &lt;img src=/Images/1660301380_1102_JLC_Products_03a_HERO_tcm96-1212560.jpg width=90 height=59 alt=1102_JLC_Products_03a_HERO(90) title=1102_JLC_Products_03a_HERO(90) /&gt;&lt;/a&gt;
            Cost and complexity are the two main reasons you don't see a photovoltaic array on every rooftop in America (except in Seattle). </description><pubDate>Fri, 6 Jul 2012 04:04:49 EST
      </pubDate><category>Photovoltaics</category></item><item><title>Duct Chases and Electrical Wiring</title><link>http://www.jlconline.com/electrical-codes/q-a--duct-chases-and-electrical-wiring.aspx?rssLink=Duct+Chases+and+Electrical+Wiring</link><description>Q: Is it okay to fish electrical wiring through the wood-framed chases built around hvac ducts and chimneys?</description><pubDate>Wed, 13 Jun 2012 04:56:43 EST
      </pubDate><category>Electrical Codes</category><category>Wiring and Cable</category><category>Framing</category><category>HVAC</category><category>Electrical</category><category>Casework</category></item><item><title>Q&amp;A: Pancake Boxes and Ceiling Fixtures</title><link>http://www.jlconline.com/drywall/q-a--pancake-boxes-and-ceiling-fixtures.aspx?rssLink=Q%26A%3a+Pancake+Boxes+and+Ceiling+Fixtures</link><description>Q: To retrofit light fixtures for old plaster ceilings that will be covered with new drywall, I plan to screw 1/2-inch-deep metal pancake boxes into the lathe of the existing ceilings and hang the new drywall around the boxes. But my electrician wants to cut into the ceiling and install deeper ceiling boxes, which will require additional blocking and more labor. He says that 31/2-inch-diameter by 1/2-inch-deep pancake boxes don't have sufficient fill capacity to make the electrical connection; is he right?</description><pubDate>Thu, 14 Jun 2012 12:04:13 EST
      </pubDate><category>Drywall</category><category>Electrical Codes</category><category>Walls and Ceilings</category><category>Metal</category><category>Fixtures</category><category>Electrical</category></item><item><title>Residential Fire Sprinklers</title><link>http://www.jlconline.com/fire-safety/residential-fire-sprinklers.aspx?rssLink=Residential+Fire+Sprinklers</link><description>
              &lt;a href=http://www.jlconline.com/fire-safety/residential-fire-sprinklers.aspx?rssLink=Residential+Fire+Sprinklers &gt;
              &lt;img src=/Images/tmp45E%2Etmp_tcm96-1144351.jpeg width=90 height=120 alt=jlc0809th_lead_fmt.jpeg(90) title=jlc0809th_lead_fmt.jpeg(90) /&gt;&lt;/a&gt;
            Your state may be the next to mandate these systems, so it’s a good idea to understand how they work .</description><pubDate>Thu, 14 Jun 2012 01:14:17 EST
      </pubDate><category>Fire Safety</category><category>Codes and Standards</category><category>Water Conservation</category><category>Electrical Codes</category><category>Residential Projects</category><category>Infrastructure Projects</category><category>Audiovisual Equipment</category><category>Plumbing</category></item><item><title>Q&amp;A: Are LEDs Okay in Closets?</title><link>http://www.jlconline.com/leds/q-a--are-leds-okay-in-closets-.aspx?rssLink=Q%26A%3a+Are+LEDs+Okay+in+Closets%3f</link><description>
              &lt;a href=http://www.jlconline.com/leds/q-a--are-leds-okay-in-closets-.aspx?rssLink=Q%26A%3a+Are+LEDs+Okay+in+Closets%3f &gt;
              &lt;img src=/Images/tmp4D%2Etmp_tcm96-1047614.jpeg width=90 height=96 alt=0209QA51_fmt.jpeg(90) title=0209QA51_fmt.jpeg(90) /&gt;&lt;/a&gt;
            Q: A client wants to install LED light fixtures in his closets, but my local code inspector is hesitant to approve them. It seems to me that an LED fixture poses no more of a fire risk than a fluorescent light. What does the code say?</description><pubDate>Thu, 14 Jun 2012 12:06:07 EST
      </pubDate><category>LEDs</category><category>Lighting</category><category>Fire Safety</category><category>Electrical Codes</category><category>Fixtures</category></item><item><title>Q&amp;A: Burying Electrical Wiring In Attic Insulation</title><link>http://www.jlconline.com/electrical-codes/q-a--burying-electrical-wiring-in-attic-insulation.aspx?rssLink=Q%26A%3a+Burying+Electrical+Wiring+In+Attic+Insulation</link><description>Q: I know that knob-and-tube wiring can't be covered with insulation, but what about BX cable and joist-mounted junction boxes? Are there any restrictions on blowing cellulose insulation into an attic and burying the cable and junction boxes?</description><pubDate>Thu, 25 Oct 2012 04:01:47 EST
      </pubDate><category>Electrical Codes</category><category>Codes and Standards</category><category>Wiring and Cable</category><category>Building Codes</category><category>Electrical</category><category>Insulation</category></item><item><title>Q&amp;A: Subpanel Bonding</title><link>http://www.jlconline.com/metal/q-a--subpanel-bonding.aspx?rssLink=Q%26A%3a+Subpanel+Bonding</link><description>Q: Is it possible to properly bond an electrical subpanel without running four-wire SER cable to it from the service-entrance panel? Some electricians have told me that under certain circumstances the subpanel can have its own ground wire and rod, while o</description><pubDate>Thu, 14 Jun 2012 12:01:36 EST
      </pubDate><category>Metal</category><category>Electrical Codes</category><category>Wiring and Cable</category><category>Electrical</category></item><item><title>Q&amp;A: To Bond or Not to Bond?</title><link>http://www.jlconline.com/electrical-codes/q-a--to-bond-or-not-to-bond-.aspx?rssLink=Q%26A%3a+To+Bond+or+Not+to+Bond%3f</link><description>Q. As a building inspector, I understand Article 250 of the most recent National Electrical Code (2005 NEC) to mean that any potential grounding electrodes available to each electrical service must be bonded together into that service's grounding electrod</description><pubDate>Thu, 14 Jun 2012 12:00:47 EST
      </pubDate><category>Electrical Codes</category><category>HVAC</category><category>Fire Safety</category><category>Electrical</category><category>Building Codes</category></item><item><title>Letters From the Editor</title><link>http://www.jlconline.com/workforce/letters-from-the-editor.aspx?rssLink=Letters+From+the+Editor</link><description>From the editor; permeance of foam in unvented attics; electrical red flag; immigration</description><pubDate>Thu, 14 Jun 2012 01:03:15 EST
      </pubDate><category>Workforce</category><category>Demographics</category><category>Insulation</category><category>Building Envelope</category><category>Electrical</category><category>Moisture Barriers</category><category>Electrical Codes</category></item><item><title>In the News</title><link>http://www.jlconline.com/electrical-codes/in-the-news.aspx?rssLink=In+the+News</link><description>
              &lt;a href=http://www.jlconline.com/electrical-codes/in-the-news.aspx?rssLink=In+the+News &gt;
              &lt;img src=/Images/tmp3C%2Etmp_tcm96-1133666.jpg width=90 height=58 alt=0907ne_AFCI.jpg(90) title=0907ne_AFCI.jpg(90) /&gt;&lt;/a&gt;
            Expanded AFCI requirements; trenching turns deadly in Southern California; nicad battery recall; more</description><pubDate>Thu, 14 Jun 2012 01:02:21 EST
      </pubDate><category>Electrical Codes</category><category>Fire Safety</category><category>Jobsite Safety</category><category>Safety</category><category>Lumberyards</category><category>Electrical</category><category>Residential Projects</category><category>Sitework</category></item><item><title>Q&amp;A: Does a Bathroom Fan/Light/Heater Unit Require a Separate Circuit?</title><link>http://www.jlconline.com/building-codes/q-a--does-a-bathroom-fan-light-heater-unit-require-a-separate-circuit-.aspx?rssLink=Q%26A%3a+Does+a+Bathroom+Fan%2fLight%2fHeater+Unit+Require+a+Separate+Circuit%3f</link><description>Q: Can a fan/light/heater unit be placed on the same circuit as the bathroom's required 20-amp receptacles, or does it require its own separate circuit?</description><pubDate>Thu, 14 Jun 2012 12:00:25 EST
      </pubDate><category>Building Codes</category><category>Electrical Codes</category><category>Codes and Standards</category></item><item><title>Replacing an Electrical Service</title><link>http://www.jlconline.com/electrical/replacing-an-electrical-service.aspx?rssLink=Replacing+an+Electrical+Service</link><description>
              &lt;a href=http://www.jlconline.com/electrical/replacing-an-electrical-service.aspx?rssLink=Replacing+an+Electrical+Service &gt;
              &lt;img src=/Images/tmp50F%2Etmp_tcm96-1128620.jpg width=90 height=61 alt=1-07PH_leadnew.jpg(90) title=1-07PH_leadnew.jpg(90) /&gt;&lt;/a&gt;
            Upgrading service equipment increases safety and load capacity while bringing the house up to code.</description><pubDate>Thu, 14 Jun 2012 12:57:04 EST
      </pubDate><category>Electrical</category><category>Electrical Codes</category><category>Panels</category><category>Fire Safety</category><category>Electrical</category><category>Residential Projects</category><category>Wiring and Cable</category></item><item><title>Q&amp;A: Moving an Electrical Box</title><link>http://www.jlconline.com/electrical-codes/q-a--moving-an-electrical-box.aspx?rssLink=Q%26A%3a+Moving+an+Electrical+Box</link><description>
              &lt;a href=http://www.jlconline.com/electrical-codes/q-a--moving-an-electrical-box.aspx?rssLink=Q%26A%3a+Moving+an+Electrical+Box &gt;
              &lt;img src=/Images/tmp31%2Etmp_tcm96-1047148.jpg width=90 height=64 alt=0406qa_compositeNEW.jpg(90) title=0406qa_compositeNEW.jpg(90) /&gt;&lt;/a&gt;
            Q: On a current kitchen remodel, my electrician placed one of the electrical boxes for the countertop outlets too low. I need to raise it about an inch to clear a stone backsplash. There's enough stripped Type NM-B cable left in the box to do this without splicing, but because the plastic sheathing has been stripped from the cable and there's no slack in the house wiring, doing so would leave an inch of unsheathed - but insulated - wiring exposed in the wall cavity behind the drywall. Is it okay to simply slip a section of plastic sheathing over the exposed wiring, perhaps using electrical tape or heat-shrink tubing to hold the sheath in place?</description><pubDate>Thu, 14 Jun 2012 11:57:29 EST
      </pubDate><category>Electrical Codes</category><category>Wiring and Cable</category><category>Drywall</category><category>Electrical</category><category>Kitchen</category><category>Countertops</category></item><item><title>Q&amp;A: Bringing Two-Wire Circuits Up to Code</title><link>http://www.jlconline.com/electrical-codes/q-a--bringing-two-wire-circuits-up-to-code.aspx?rssLink=Q%26A%3a+Bringing+Two-Wire+Circuits+Up+to+Code</link><description>Q. What's the quickest and easiest way to bring a two-wire circuit up to code?</description><pubDate>Thu, 14 Jun 2012 11:56:29 EST
      </pubDate><category>Electrical Codes</category><category>Wiring and Cable</category><category>Panels</category><category>Metal</category><category>Electrical</category><category>HVAC</category></item><item><title>Q&amp;A: Limits on Outlets</title><link>http://www.jlconline.com/electrical-codes/q-a--limits-on-outlets.aspx?rssLink=Q%26A%3a+Limits+on+Outlets</link><description>Q. How many receptacles can I put on a 15-amp and a 20-amp circuit?</description><pubDate>Thu, 14 Jun 2012 11:56:07 EST
      </pubDate><category>Electrical Codes</category><category>Commercial Construction</category><category>Electrical</category><category>Residential Projects</category><category>Living Room</category></item><item><title>In the News</title><link>http://www.jlconline.com/codes-and-standards/in-the-news-3.aspx?rssLink=In+the+News</link><description>
              &lt;a href=http://www.jlconline.com/codes-and-standards/in-the-news-3.aspx?rssLink=In+the+News &gt;
              &lt;img src=/Images/tmp43%2Etmp_tcm96-1106305.jpg width=90 height=66 alt=1004ne-05.jpg(90) title=1004ne-05.jpg(90) /&gt;&lt;/a&gt;
            Lessons from Hurricane Charley; stray voltage zaps homeowners; building code comes to Pennsylvania; NAFTA panel slams U.S. on tariffs</description><pubDate>Thu, 14 Jun 2012 12:43:01 EST
      </pubDate><category>Codes and Standards</category><category>Government Projects</category><category>Building Codes</category><category>Electrical Codes</category><category>Residential Construction</category><category>Electrical</category><category>Panels</category></item><item><title>In the News</title><link>http://www.jlconline.com/fire-safety/in-the-news-7.aspx?rssLink=In+the+News</link><description>
              &lt;a href=http://www.jlconline.com/fire-safety/in-the-news-7.aspx?rssLink=In+the+News &gt;
              &lt;img src=/Images/tmp14AF%2Etmp_tcm96-1097089.jpg width=90 height=62 alt=1003nb-106.jpg(90) title=1003nb-106.jpg(90) /&gt;&lt;/a&gt;
            Nail gun accidents, California picks NFPA code, Minnesota stucco warning, mega-home tally, Business Tune-Up</description><pubDate>Thu, 14 Jun 2012 12:32:31 EST
      </pubDate><category>Fire Safety</category><category>Building Codes</category><category>Stucco</category><category>Codes and Standards</category><category>Electrical Codes</category><category>Residential Projects</category><category>Residential Construction</category></item><item><title>Q&amp;A: Insulating Around Knob-and-Tube</title><link>http://www.jlconline.com/insulation/q-a--insulating-around-knob-and-tube.aspx?rssLink=Q%26A%3a+Insulating+Around+Knob-and-Tube</link><description>Q. I am remodeling a 1920s house that has the original knob-and-tube wiring. I would like to blow cellulose into the stud cavities but am guessing that it's not safe to do that with the exposed wiring in the cavities. What does code say?</description><pubDate>Thu, 14 Jun 2012 11:52:30 EST
      </pubDate><category>Insulation</category><category>Electrical</category><category>Wiring and Cable</category><category>Electrical Codes</category></item><item><title>Notebook</title><link>http://www.jlconline.com/basement/notebook.aspx?rssLink=Notebook</link><description>NAHB pulls out of NFPA code process, new device for drying basements, California claimed unfair to nonunion apprenticeship programs, suburb’s no-step entry requirement dropped, Business Tune-Up, more</description><pubDate>Thu, 14 Jun 2012 12:21:42 EST
      </pubDate><category>Basement</category><category>Building Codes</category><category>Codes and Standards</category><category>Fire Safety</category><category>Government Projects</category><category>Associations</category><category>Electrical Codes</category></item><item><title>Q&amp;A: GFCI Protection for Shower Lighting</title><link>http://www.jlconline.com/fixtures/q-a--gfci-protection-for-shower-lighting.aspx?rssLink=Q%26A%3a+GFCI+Protection+for+Shower+Lighting</link><description>Q: In a bathroom remodel, we plan to install a light fixture in a shower stall, with a switch near the shower door. Do the fixture and switch need to be GFCI-protected?</description><pubDate>Thu, 14 Jun 2012 11:49:27 EST
      </pubDate><category>Fixtures</category><category>Electrical Codes</category><category>Bath</category><category>Shower</category><category>LEDs</category></item></channel></rss>
