Launch Slideshow
Caulks, Sealants, and Adhesives
New products from around the adhesives and air-sealing industry.
  • http://www.jlconline.com/Images/2115587184_0212d_rm_PRODIF3_DAP_Web_tcm96-1081236.jpg
    600
    Match it Up The DAP Spec Line is the first collection of sealants and adhesives designed specifically to meet industry specs for certain job types. Aligned with the most common specs for window, door, siding, subfloor, and drywall applications, each product in the series is named for the spec it meets. For example, window sealant DraftStop 812 meets AAMA 812, while DynaGrip 3498 meets ASTM D3498. Siding sealant DynaFlex 920 (which meets ASTM C920) features an additional labeling convention that identifies the exact brands of siding that color of sealant complements. DAP - 800-543-3840 - dapspecline.com
  • http://www.jlconline.com/Images/40407346_0212d_rm_PRODIF3_Dow_Web_tcm96-1081237.jpg
    300
    Pest Protection Seal gaps and cracks around the house and simultaneously prevent entry for pests with Great Stuff Pestblock. Designed to keep out ants, roaches, spiders, bees, mice, and other rodents while also air sealing the structure, Great Stuff expands to fill, seal, and insulate gaps up to 1 inch. Ideal for use around common trouble spots, such as gaps surrounding PVC pipes, dryer and exhaust vents, sill plates and rim joists, under baseboards, around plumbing and faucets, and attic hatch frames. Dow - 866.583.2583 - dowbuildingsolutions.com
  • http://www.jlconline.com/Images/286305382_0212d_rm_PRODIF3_GacoWestern_Web_tcm96-1081238.jpg
    300
    Roof Repair Silicone-based and solvent-free GacoSeamSeal comes in a liquid formulated with a unique thickening agent that gives the material the properties of traditional roof tape as it dries. Unlike roof tape, however, GacoSeamSeal can be applied with a brush, trowel, piping bag, or roller for faster and easier work. Following GacoSeamSeal application, roofing installers can use the maker's GacoFlex S-20 to apply a complete silicone coating to the roof for long-lasting waterproofing. Gaco Western - 877.699.4226 - gaco.com
  • http://www.jlconline.com/Images/815454937_0212d_rm_PRODIF3c_LiquidNails_Web_tcm96-1081241.jpg
    300
    Sound Off In combination with the maker’s drywall adhesive, Acoustical Sound Sealant helps create a complete wall system that reduces drafts and deadens noise. The sealant maintains the wall’s specific Sound Transmission Class and has been tested to ASTM standards for flame spread and smoke generation. It is nonflammable, low-odor, VOC-compliant, and can be cleaned with water. Liquid Nails - 800.634.0015 - liquidnails.com
  • http://www.jlconline.com/Images/1138631209_0212d_rm_PRODIF3a_Loctite_Web_tcm96-1081239.jpg
    300
    Grab Hold With nearly nine times the tack of competitive products, according to the maker, Power Grab Clear Construction Adhesive dries clear for a smooth finish. The adhesive helps hold projects in place without the need for nailing or bracing, and can be repositioned for up to 15 minutes. Bonds to wood, drywall, concrete, and rigid plastic, and is ideal for a range of projects from installing drywall to repairing retaining walls. Loctite - 800.624.7767 - loctiteproducts.com
  • http://www.jlconline.com/Images/1070678950_0212d_rm_PRODIF3b_Sashco_Web_tcm96-1081240.jpg
    300
    Clean Seal Backed by a seven-year product and labor-cost replacement warranty, MildewFree kitchen and bathroom caulk is guaranteed to prevent mildew growth on the sealant. The elastomeric material is also designed to stretch without tearing, cracking, or pulling away. A 6-ounce tube of MildewFree is enough to caulk an average shower enclosure. The material resists damage from abrasive cleaners, and cleans up easily with water. Sashco - 800.289.7290 - sashco.com
Product innovators at DAP unveiled new features and products at the Remodeling Show last fall, setting their sights on exterior contractors. The new DAP Spec Line capitalizes on the maker’s existing adhesive and sealant technologies to create new products for windows, doors, and siding. Moreover, a unique naming convention helps ensure that contractors choose the right product for the job.
“People have been trying to simplify this category for years,” says Mark Longo, vice president and general manager of DAP’s WDS division. “Now with the new line, you’re assured that the product you’re using meets the right criteria for the job.” Each DAP Spec Line product is named for the installation criteria installers are most likely to use. For example, siding contractors working with ASTM C920 would choose DynaFlex920, easily spotted with the labeling.
Longo says that DAP’s Spec Line has been well received in the market since its introduction, and the company is looking forward to rolling out another innovation in February and March 2012. “We’re ramping up production for a full color palette for DynaFlex920,” he says. Thanks to DAP’s in-line pigmenting technologies, the sealant will be color-matched to nearly the full array of colors available from siding manufacturers throughout the industry.
Specialized labeling on each tube will show contractors which sealant matches the brand and color of siding they’re using. Learn more on dapspecline.com where there will be a full-color cross-reference tool.
—Lauren Hunter, associate editor, REMODELING.
