by Clayton
DeKorne
In the U.S. market, there are literally thousands of window lines
to choose from. Chris Mathis of MCSquared, a building-science
consulting firm that focuses on windows, doors, and skylights,
underscores this fact by explaining that it doesn't take much to
get into the window-manufacturing business and capture local
markets with cut-rate pricing. "These are the companies," Mathis
cautions, "that may not be around when the glass fails."
Warranty First
To pick a window that will last, start with the warranty, Mathis
advises. Look for a non-prorated, transferable warranty good for 20
years on the glass and at least 10 years on non-glass parts. These
solid warranties are available from most of the bigger window
companies, but Mathis says it's surprising how many companies do
not offer such a warranty at all, or do not offer it on all their
window lines. This reflects a serious compromise in the quality of
a large percentage of the windows sold. Nearly 30% of the
replacement windows installed today will replace windows that are
only seven years old, reports Mathis. "That's a sad commentary on
the quality of many windows out there."
Common failures. The most common window
failure is the breakdown of the seal on an insulated glass unit. If
the seal blows, the window will fog up between the panes, and a
lost seal causes a drastic reduction in window R-value. Even if the
seal fails gradually, air and moisture slowly entering the
windowpane tends to oxidize the low-E coating, turning it into a
high-E coating that absorbs heat rather than reflects it away. This
oxidation will look exactly like the salt spray that sticks to the
glass, except that it can't be washed off. It looks like a
permanent blur between the windowpanes.
All windows, regardless of where they are sold, should carry a
good warranty and meet basic structural and thermal performance
measures. On the coast, however, high wind loading makes it
imperative that windows further meet enhanced structural measures,
and the frequent occurrence of wind-driven rain demands giving a
second look to test results for water leakage.
While a 20-year glass warranty will adequately cover this most
common window failure, a warranty on non-glass parts also becomes
especially significant on the coast. Constant humidity, blowing
rain, and salt attack will quickly degrade cheap finishes and
hardware, and hinder sash movement.
Mathis, a former director of the National Fenestration Rating
Council (NFRC) who now serves on the ASHRAE and ASTM code
committees as well as on the International Energy Conservation Code
Committee of the ICC, urges that choosing a manufacturer that will
be around in 10 years to replace deteriorated parts may be the most
important window selection criterion of all.
Warranty language. "If a window says ‘lifetime
warranty,' it makes me nervous," says Mathis. "‘Lifetime' is
usually written in big, bold letters, but you have to read the fine
print to find out what this really means." Many warranties seem to
cover a lot up front, but that impression quickly changes when all
the details are spelled out.
Language to look for:
• "Non-prorated" warranties will cover the
entire purchase price of the window for the term of the warranty.
Unlike roofing materials, a well-made window shouldn't gradually
degrade with exposure, so there is little justification for a
prorated warranty.
• "Fully transferable" warranties are a sign
that the window maker means business. For a homeowner selling a
home, it can be a value-added feature that a builder or remodeler
can make available when recommending a window.
• "Non-glass" components, particularly
hardware, should carry a minimum 10-year warranty. A good window
with bad hardware is a bad window, Mathis insists. If a lock breaks
or the crank handle strips out, it will reflect poorly on the
remodeler who installed the window. Think about the window
manufacturer's capacity to stock replacement parts well into the
future.
• Labor and installation. Unless a certified
representative of the manufacturer installed the unit, few
warranties will cover the cost of installation. Some may, but for
the most part, this will fall to whoever installed the window. This
is yet another reason for builders and remodelers to stick with
trustworthy brands.
• Exclusions. This is key in coastal
climates. Some warranties specifically exclude coverage for damage
from environmental factors, such as high humidity or salt spray.
The exclusion may apply to the glass as well as to the hardware and
finishes.
• Finishes. Coverage on finishes is rare, but
some warranties do cover exterior coatings and finishes on
cladding. However, painting or refinishing the exterior to match
the home may null this coverage. This is particularly true on
aluminum-clad and vinyl units.
Mathis contends that if the warranty passes muster, you are
probably dealing with a manufacturer willing to protect its
reputation. Behind that reputation will be reliable performance
specifications. So, in addition to the warranty, you want to look
for an NFRC label that outlines the window's energy performance and
an AAMA label that provides third-party assurances of basic
structural performance and establishes a norm for air leakage and
water penetration.
Baseline Energy Specs
Much ado is made over low-E coatings — the invisible thin
metallic coatings that block radiant heat flow — as well as
other energy features, such as gas fills and low conductivity edge
spacers. However, builders rarely have the option to choose these
à la carte. One useful tool is to compare the performance
values for various window configurations available using the
Efficient Windows Collaborative's online Window Selection Tool
(www.efficientwindows.org). But to make sense of this,
you need to understand the baseline measurements of window
performance.
Every window worth its salt comes with a label from the NFRC that
provides a simple standard for window energy performance (Figure
1). Four numbers on this label describe the impact of the entire
window unit, not just the glass, on the heating and cooling load of
the building. However, only two these — the U-factor and the
solar heat gain coefficient (SHGC) — bear close
scrutiny.
Figure 1.An NFRC label rates the
basic energy performance of a window using two critical numbers:
the U-factor, which measures heat flow, and the solar heat gain
coefficient (SHGC), which measures the percentage of radiant heat
energy that will pass through the window. For optimal performance
in all climates, both numbers should be below 0.35.
U-factor is a measure of heat flow (and the inverse
of R-value). The lower the U-factor, the less heat will move
through the entire window. Mark LaLiberte of Building Knowledge
Training Services, a national training and education consultancy
that works with many of the nation's top home builders, recommends
a U-factor of 0.35 or less, regardless of the climate in which you
build. LaLiberte, a team adviser for the Department of Energy's
Building America program, acknowledges that this recommendation is
more conservative than the Energy Star program, which allows
U-factors up to 0.65 in hot climates where radiant solar heat gain
is of much greater concern than conductive heat flow (The Energy
Star program divides the country into four climate regions and sets
prescriptive and performance values for maximum U-value and SHGC.
These values can be found at www.energystar.gov, then navigating to the
Windows, Doors and Skylights energy-efficiency guidelines.)
Solar heat gain coefficient (SHGC)
measures the amount of solar heat gain that passes through a
window. An SHGC of 0.35 means that 35% of the radiant heat striking
the window will pass through the glass, while 65% will be reflected
back outdoors. The lower the SHGC, the lower the cooling load on a
home will be. Janet McIlvaine, a research analyst at the Florida
Solar Energy Center, urges that a "low solar heat gain" window of
SHGC 0.35 is best for hot climates. In cooler climates, designers
sometimes spec windows with a higher SGHC, wishing to capitalize on
solar heat gains. The most common strategy is to design the home
with a 2-foot overhang (the widest overhang usually allowed in
high-wind regions) to shade the windows from the high summer sun,
and select a window with a SHGC above 0.50 to capture solar gains
in winter when the sun is low. But LaLiberte, Mathis, and McIlvaine
all caution that this strategy should be employed only when the
orientation and shading of windows can assure that the windows
won't "see" the hot summer sun. Anywhere air conditioning is used
during the summer, a low-SHGC window is a safer bet.
Visible-light transmittance (VT) refers to the amount
of daylight passing through the entire window area. The heavier the
frame and the more divided lights a window has, the lower the VT
will be. This number is far more important in commercial buildings,
which often use heavily tinted or mirrored glazing that can reduce
daylighting possibilities and increase electric lighting costs. For
residential windows, McIlvaine advises that the VT rating should be
higher than the window's SHGC. That is, there should be more light
than heat coming through the glass. But otherwise, it's not a
number worth sweating over.
Air leakage (AL) ratings are expressed as
an equivalent cubic feet of air passing through a square foot of
window area. The lower the AL, the less air will leak through the
window assembly. However, this rating is optional, and rarely
included on residential windows, even though more energy is usually
lost from air infiltration and exfiltration than by conduction or
radiation. The justification put forward by some manufacturers for
not including this rating is that air leakage between the rough
opening and the window unit has the potential to carry away far
more than heat than would leak through the unit. The bottom line:
Be sure to properly seal the window rough opening with spray
foam.
Impact-Resistant Windows
By now, impact-resistant windows using laminated glass are nothing
new to coastal builders and remodelers. Many of the technical
difficulties we reported last year ("Speccing Windows in High-Wind
Zones," Winter 2005; available online at www.coastalcontractor.net) have been worked out, and
manufacturers are offering a wider selection of sizes of windows in
a much broader range of design pressures (Figure 2).
Figure 2. Just a couple years ago, windows
featuring impact-resistant glass were available in only a limited
range of sizes. Now manufacturers competing in the coastal market
offer a range of windows with a wide range of design pressures,
making compliance with the International Residential Code wind
requirements much easier.
Impact resistance is tested by firing a 2x4 missile at the window
and evaluating how well it then holds up to pressure cycling
— a test that is intended to simulate the forces of
wind-borne debris striking the window during a hurricane (Figure
3). An impact-resistant window typically shatters during an impact
test but maintains its integrity if the interlayer and glass shards
hold together. While keeping the home and its occupants out of
danger, the window will leak significantly.
Figure 3. An
impact-resistant window can shatter and still pass the large
missile test if the window remains largely intact through the 9,000
pressure cycles. The glass fragments tend to adhere to the plastic
interlayer, which is considered intact if the size of any rips that
develop during the test total less than 1/16 inch wide by 5 inches
long.
Opening protection. Installing impact-resistant
windows is just one way to meet the structural requirements for
wind-blown debris, but it is the most convenient method and, for
vacation homes, at least, it may be the most practical (Figure 4).
If windows without laminated glass are used, a house must be
shuttered during a tropical storm.
Figure 4. Many windows would be very difficult
to reach to install shutters, making impact-resistant windows the
only practical choice for a range of residential
buildings.
However, though more convenient, impact-resistant windows do not
necessarily offer the best protection. According to the Institute
for Business and Home Safety (IBHS), steel storm panels that meet
the Dade County standards for opening protection offer the highest
level of protection possible. These products will prevent the
windows behind them from breaking and keep water out better than
impact-resistant windows or movable shutter systems. Plywood can be
used for shutters, but according to the IBHS, to get near the
protection offered by Dade County-approved storm panels requires
3/4-inch plywood, which makes for heavy shutters that are difficult
to install. (IBHS recommends plywood over OSB, as it takes 30%
thicker OSB to equal the impact resistance of plywood. See
"Evaluating OSB for Coastal Roofs," Winter 2005; available at
www.coastalcontractor.net.) Lighter 3/8-inch-thick
plywood shutters offer only about half as much resistance to
penetration as 3/4-inch plywood and provide few assurances that the
building shell will not be breached during a major storm. Clear
polycarbonate shutters offer nearly the same impact resistance as
storm panels and are relatively light. Roll-down shutters, the most
convenient option, often require putting up storm bars to offer
adequate impact resistance.
The convenience offered by impact-resistant laminated glass may
also mean the difference between adequate protection for the
structure and its occupants or none at all. Post-hurricane damage
assessments always turn up evidence of homes that were damaged
because owners were unable to make arrangements to install shutters
before a major storm struck. "Shutters," argues Dave Olsen, a code
expert with Florida-based window maker PGT Industries, "demand that
the homeowner is home, and able, to install them."
Cost. The most frequently cited
shortcoming of impact-resistant glass is the cost. The added cost
per unit varies with window size, shape, and design pressure (DP).
Large windows, circle tops, and high-DP units add proportionally
more to the price tag. Price quotes in the Florida and Virginia
markets for double-hung units by several different manufacturers
revealed costs for impact-resistant windows $150 to $350 higher
than comparable units with conventional insulated glazing (for an
added cost of about $13 to $30 per square foot of window area, with
aluminum and vinyl windows at the lower end of the price range and
clad wood at the upper end). This increase works out to $4,160 to
$9,600 for 320 square feet of window area (or 20% window-to-floor
area in a 1,600-square-foot home). In many southeastern markets,
such an upcharge, which does not include markup or any added labor,
might be a significant increase to the cost of a house, but in most
housing markets along the mid-Atlantic and New England coast, it
would likely be a relatively small proportion of the total house
price.
Window manufactures cite a study commissioned by the North American
Laminated Glass Information Center, which concludes that the cost
for laminated glass is less than the installed cost of roll-down
shutters — the most convenient but also most expensive
shutter option available. The "Hurricane Shutter Guide" published
by the South Florida Sun-Sentinel confirms this conclusion,
estimating the installed cost of roll-down shutters to be $26 to
$40 per square foot, or $8,320 to $12,800 for the equivalent window
coverage used to compare window costs as noted above (320 square
feet). The installed cost for the equivalent size and number of
steel storm panels ranges from $1,280 to $2,240 —
considerably less than the upcharge for laminated glass but
considerably less convenient as well.
Added value. The benefits to using laminated glass go
far beyond convenience in meeting the destructive force of a
tropical cyclone. The clear advantages that should help justify the
higher costs for impact-resistant windows include:
• Security. It's as difficult for a burglar
to shatter a laminated windowpane as it is for a wind-blown roof
tile to smash through it. Therefore, this option is especially
attractive for vacation homes that are unoccupied for much of the
year. Few beach communities allow homes to remain shuttered for
more than a few hours before and after a storm (and few homeowners
would be wise to do so, as it is an invitation to burglars, who
will know nobody's home). Laminated glass also provides a measure
of safety protection: Children are unlikely to fall through a
laminated window or get hurt by a broken pane.
• Sound dampening. Glass is inherently
brittle and readily transmits sound vibrations. Adding a flexible
interlayer has the same effect as putting a finger on a drumhead:
It deadens the vibration. An ordinary double-pane insulated glass
window has a sound transfer coefficient (STC) of 28. When made with
laminated glass, the window's STC jumps to 35 — about the
same as an insulated 2x4 wall with 5/8-inch drywall on both
sides.
• UV protection. The plastic interlayer
blocks ultraviolet light, which might otherwise cause carpets and
home fabrics to fade and vinyl flooring to yellow.
PGT's Olsen says that laminated glass has become a standard feature
on a majority of windows sold in Europe, not for protecting homes
from hurricanes but for the increased security, safety, and sound
resistance afforded by these units. And he points to the fact that
prices have fallen as manufacturers have become more familiar with
the thicker glazing and have filled out their window lines.
Design Pressure
Impact resistance and design pressure are two distinct structural
requirements for windows used in hurricane zones: One resists
failure from wind-blown debris, and the other resists failure
caused by sustained wind pressure.
Wind pressures are simulated in the laboratory by applying a static
pressure across a window specimen for a prescribed amount of time
and measuring the maximum uniform load deflection (Figure 5).
During this test, pressure is applied in both directions,
simulating sustained positive and negative wind loads. Design
pressure will vary with area, so the window dimensions are critical
to choosing the correct design pressure.
Figure 5. The Pressure Test: In the
laboratory, wind pressures applied to a window in a high-wind event
are simulated by applying a static pressure across a random window
specimen for a prescribed amount of time and measuring the maximum
uniform load deflection.
To comply with the International Residential Code, all windows in
high-wind zones must meet the "Components and Cladding"
requirements, found in prescriptive tables listing minimum design
pressures for windows in different positions on the house exterior.
For example, windows placed near corners, where the wind pressures
are highest, must have a higher design pressure. (For a detailed
discussion of these window performance requirements, see again
"Speccing Windows in High-Wind Zones," Winter 2005; available
online at www.coastalcontractor.net.)
The design pressures used to meet the code's "Components and
Cladding" requirements should not be confused with the pressure
ratings that are central to the joint specification from the
American Architectural Manufacturers Association (AAMA) and the
National Wood Window and Door Association (NWWDA). Known as
AAMA/NWWDA 101/I.S.2 (or shorthand as AAMA 101), this standard
defines the baseline performance characteristics required for every
window, regardless of the market. The primary specification is a
"structural test pressure" rating, which is established using a
test procedure developed by ASTM that evaluates the window after
applying a pressure 50% higher than the design pressure. If no
permanent deformation occurs to the window, it passes the test and
is awarded a small gold label affixed to an inside surface of the
frame (Figure 6). However, the minimum design pressure rating
listed in AAMA 101 may be lower than what is required for
"Components and Cladding." For example, the AAMA 101 baseline for
residential-class windows starts at a minimum design pressure of 15
psf. While this pressure is equivalent to the pressure sustained by
a 75-mph wind — the defining wind speed for a Category 1
hurricane — it would not pass muster in any coastal wind
zone.
Figure 6. On this AAMA label, F-HC40-96x72 is
the critical designation for this window. F is the product type
(Fixed); HC is the performance class (Heavy Commercial); 40 is the
performance grade (40 psf design pressure); and 96x72 is the
maximum size tested (width x height).
Currently, the AAMA 101 draws a distinction between several classes
of windows, with residential (R) at the low end of the design
pressure range, and heavy commercial (HC) and an unspecified
"architectural" (AW) class at the upper end. Dean Lewis, manager of
product certification for the AAMA, has suggested that these
distinctions may become obsolete as more and more residential
windows are being made to meet higher design pressures.
Water Penetration
In addition to the structural performance ratings, AAMA 101 also
establishes minimum air infiltration and water penetration values
(Figure 7). The water penetration values are found using an ASTM
test procedure that applies a negative pressure equal to 15% or 20%
(depending on the window's performance class) of the design
pressure to the inside of the test assembly, and then hoses the
window exterior with a rack of water jets that is equivalent to a
rainfall of 8 inches per hour (Figure 8). At best, a window meeting
the AAMA 101 spec will leak in a 35-mph wind, which virtually
guarantees it will leak in a hurricane.
Missing Table Here
Figure 7. The water resistance value required for the
AAMA/NWWDA 101/I.S.2 standard is 15% of the design pressure for all
window class, except Architectural class, which requires a water
penetration resistance at 20% of design pressure. While required by
code for any window, this standard is not intended to evaluate the
performance of windows in hurricane zones. All windows that meet
these basic performance criteria will leak in any major tropical
storm.
Figure 8. The Water Test: To meet AAMA minimum
water penetration rating, a sample window is subjected to a
negative pressure equal to 15% or 20% of the design pressure across
the inside of the test assembly. The window exterior is then hosed
down with a rack of water jets that is equivalent to a rainfall of
8 inches per hour. If any leakage occurs on the interior, the
window does not pass.
The assessment of Joe Lstiburek of Building Science Corporation is
even worse: In developing a report commissioned by the Florida Home
Builders Association to evaluate the high incidence of water damage
to homes during the 2004 hurricane season, Building Science Corp.
found that most windows leak when no pressure is applied. For that
report, Building Science Corp. tested 50 windows. "We had 100%
failure," notes Lstiburek. "Okay, it was ‘only 50 windows,'
you might say. ‘There are thousands of windows available.'
But when every one of them leaked, we felt pretty safe drawing the
general conclusion that windows leak."
The AAMA acknowledges the problem and issued the statement: "The
lesson learned in 2004 is that water penetration from heavy
wind-driven rains occurred in more cases than acceptable, leading
to interior water-related damage that could have been prevented."
And an AAMA Southeast Region Hurricane Standard Development Task
Group is currently gathering data on real-world indoor/outdoor
pressure differentials due to hurricane-force winds to find ways to
better simulate actual wind gusting and effects of turbulent wind
flow.
But despite his report, Lstiburek feels that the results should be
kept in perspective. For starters, he contends, it's significant
that the windows won't blow out, and the occupants can remain safe
inside during a major wind event. In addition, the water leakage
for windows is not just a shortcoming for the windows. "There are
no standards for the walls, which will leak much more than the
windows," said Lstiburek. "The point is, let's accept that walls
and windows leak. But let's design them to first drain to the
exterior, and second to dry out if they do get wet. That's the best
way to avert widespread water damage." If the main criterion is
reducing water leakage, Lstiburek recommends sealing the roof vents
where the most water is likely to come into a home, and cause the
most damage, during a hurricane. ~
Clayton DeKorneis the editor of Coastal
Contractor.
