Download PDF version (301k) Log In or Register to view the full article as a PDF document.
The Tranquility 27 Series geothermal heat pump is ClimateMaster’s latest and most efficient unit, with an EER rating of 27. The unit uses a zero-ozone-depletion refrigerant, has a two-stage blower motor, and comes standard with a MERV 11 filter system. A 4-ton unit costs $5,180, independent of the required ground loop. ClimateMaster, 877/436-6263, climatemaster.com.
