Electrical Basics
JLC Field Guide: Electrical Basics
Whether you're starting out or a veteran contractor, understanding basic definitions and materials is the first step to working successfully with your trade partners.
Learn More
Electrical Basics Featured Articles
Job-Site Power: Handle With Care
An electrician discusses several options for safe, economical temporary job-site... More
Temporary Construction Power Box - Build your own!
If you build or remodel homes for a living you've definitely encountered times when the crews didn't have enough power. Here's how we bring a portable power panel to our jobs to get everyone connected. More
Electrical Problem-Solvers
When it comes to wiring, these tools and products can save you time and money More
Common Electrical Inspection Failures
The last thing a gerneral contractor needs is to have a job put on hold because of a failed electrical inspection. A master electrician shows how to identify the trouble spots before the inspector does. More
Plug-In Electrical Testers
Using an inexpensive tester, you can troubleshoot a miswired receptacle without... More
View All >
Electrical Basics Instruction
Grounding Electrical Boxes
Is using a grounding screw required when working with metal electrical boxes? And what about grounding when using plastic boxes? More
Pigtails for Switches?
Is there any advantage to wiring switches with pigtails? More
Q&A: Sizing Electrical Boxes
What are the guidelines for determining box size, and how can you prevent overcrowding? More
Rookie Builder Mistakes - Part 1 - Electrical
Have you ever lost a project because you were too "expensive"? Aren’t the plans... More
Q&A: Outlet on Boxed Column
If you box in a Lally column in a finished basement, does code require that you... More
View All >
