Finish Wiring
JLC Field Guide: Finish Wiring
In the final phase of an electrical installation, lighting fixtures and devices such as switches and receptacles are installed, appliance connections are made, and utilities (boilers or furnaces, air conditioning, well pumps, etc.) are connected.
Learn more
Finish Wiring Featured Articles
Plug-In Electrical Testers
Using an inexpensive tester, you can troubleshoot a miswired receptacle without... More
Neutral Necessity: Wiring Three-Way Switches
In the latest National Electric Code, every switch box in a habitable room or... More
Electrical Problem-Solvers
When it comes to wiring, these tools and products can save you time and money More
Wiring The High-Tech House
Structured wiring is the backbone that makes home automation work. More
How to Remodel Around Electrical Systems
A master electrician advises you on how to do your work without accidentally damaging his. More
View All >
Finish Wiring Instruction
Grounding Electrical Boxes
Is using a grounding screw required when working with metal electrical boxes? And what about grounding when using plastic boxes? More
Pigtails for Switches?
Is there any advantage to wiring switches with pigtails? More
Q&A: Sizing Electrical Boxes
What are the guidelines for determining box size, and how can you prevent overcrowding? More
View All >
