Low-Voltage Wiring
Kitchen & Bath: Low-profile Undercabinet Lighting
Low-profile undercabinet lighting More
Wiring The High-Tech House
Structured wiring is the backbone that makes home automation work. More
Undercabinet Lighting Options
Fluorescent strips are not the only choice for task lighting below wall cabinets. This overview explains the difference between halogen, xenon, and fluorescent lamps and sorts through the various fixtures available. More
View All >
Low-Voltage Wiring Instruction
Grounding Electrical Boxes
Is using a grounding screw required when working with metal electrical boxes? And what about grounding when using plastic boxes? More
Pigtails for Switches?
Is there any advantage to wiring switches with pigtails? More
Quick Fix for a Noisy Circulation Fan
Q. My client's metal fireplace is supplied by a makeup air system with a built-in... More
Tags: Electrical, Metal, Ventilation, Acoustics, Fireplaces
Burying Electrical Wiring In Attic Insulation
Q: I know that knob-and-tube wiring can't be covered with insulation, but what about BX cable and joist-mounted junction boxes? Are there any restrictions on blowing cellulose insulation into an attic and burying the cable and junction boxes? More
Using A Volt-Ohm Meter
A master electrician describes how to trace wires, identify circuits, and diagnose common job-site electrical problems. More
View All >
