Main Service
JLC Field Guide: Main Service
In this section of the JLC Field Guide, we address what is often called the load center or just the electrical panel, but which; includes the service entrance that feeds into, and any subpanels that might feed off of, the main panel.
Learn More
Replacing an Electrical Service
Upgrading service equipment increases safety and load capacity while bringing the... More
The Electrical Panel
In this guided tour of a distribution panel, a master electrician tells how to make sure an electrical system is wired safely and correctly grounded. More
Installing Solar Electric Power
A photovoltaic system should be properly sized, built to code, and installed so... More
Job-Site Power: Handle With Care
An electrician discusses several options for safe, economical temporary job-site... More
Getting Power to the Site
Whether you have an electrician make up a temporary pole, rent one, or make a deal with a neighbor, safety should be a primary concern. Here’s one contractor’s approach. More
View All >
Main Service Instruction
Grounding Electrical Boxes
Is using a grounding screw required when working with metal electrical boxes? And what about grounding when using plastic boxes? More
Pigtails for Switches?
Is there any advantage to wiring switches with pigtails? More
Wind- and Solar-Powered Generator
Batteries that are recharged by solar panels and a wind generator supply DC power... More
Q&A: Service-Entrance Cable Under a Garage
Q: The proposed location for my client's new detached garage is right on top of a buried service-entrance cable. The electric meter is mounted on a pedestal about 100 feet from the house, and a conduit runs to the house through the area where the garage — More
Moving an Electrical Box
Q: On a current kitchen remodel, my electrician placed one of the electrical boxes... More
View All >
