A.Rex Cauldwell, a master electrician in Rocky Mount, Va., responds: Noisy single-speed fireplace fans are common. To reduce the fan’s speed — which can help solve the problem — I use a Dial-A-Temp control (866/667-8454, northlineexpress .com). This device (see photo, below) plugs into a 120-volt receptacle; the fireplace fan, in turn, plugs into it. Rated for motor loads up to 3 amps and 300 watts, it has both an on/off switch and a variable-speed switch. It costs about $20.
Remember that you can’t use a light dimmer on a fan motor. Dimmers are designed for resistive devices — like the filament of a light bulb — and operate by lowering the voltage to the lamp. A fan motor is a capacitive and inductive device that needs a relatively constant voltage to keep it from overheating and burning out. A motor speed...
