Rough Wiring
JLC Field Guide: Rough Wiring
Not all municipalities will allow unlicensed electricians to do electrical work but many will. Even if not allowed in your jurisdiction, however, understanding what all trade partners are doing is essential for guiding the job and ensuring a timely completion and successful inspection.
Learn More
Rough Wiring Featured Articles
Running Wire in Conduit
EMT costs more up front, but it's less likely to get damaged and makes future... More
Rewiring Old Houses
A master electrician shows the tools and techniques he uses to snake new wires in... More
Electrical Problem-Solvers
When it comes to wiring, these tools and products can save you time and money More
Wiring The High-Tech House
Structured wiring is the backbone that makes home automation work. More
Plug-In Electrical Testers
Using an inexpensive tester, you can troubleshoot a miswired receptacle without... More
View All >
Rough Wiring Instruction Articles
Electrical Rough-In
Rough Wiring
Not all municipalities will allow unlicensed electricians to do electrical work but many will. Even if not allowed in your jurisdiction, however, understanding what all trade partners are doing is essential for guiding the job and ensuring a timely completion and successful inspection. More
Grounding Electrical Boxes
Is using a grounding screw required when working with metal electrical boxes? And what about grounding when using plastic boxes? More
Pigtails for Switches?
Is there any advantage to wiring switches with pigtails? More
Q&A: Sizing Electrical Boxes
What are the guidelines for determining box size, and how can you prevent overcrowding? More
View All >
