Mark Parlee
Most of my work is in exterior remediation, both as a builder specializing in exterior work and (more and more these days) as a building consultant inspecting and advising owners and builders when moisture problems arise. I see a lot of failures, and most of the hands-on work we do is fixing other builders' mistakes. Daily I am reminded of the need for wider understanding of best practices, and that is especially true with adhered concrete masonry veneer (ACMV). We call this material "stone," but we all know that it is a non-load-bearing concrete cladding made to look like pieces of stone set in mortar that is bonded to a stucco scratch coat. We really need to be treating this material like stucco with chunks of concrete in it. When we lose sight of that, problems arise.
ACMV has been increasing in popularity as a cladding on mid-range and high-end homes for the last decade, and across the Midwest where I work, a huge number of these homes are now showing signs of water-damage because the ACMV wasn't installed correctly the first time. I am an Exterior Design Institute (EDI) third-party EIFS and building...
