Board Siding
JLC Field Guide: Board Siding
Problem-free siding installations start with selecting the right siding grades and controlling the moisture content of the wood.
Learn More
Getting Kickout Flashings Right
Leaks are a liability. It's so much easier and less expensive to invest in $15... More
Rainscreen Clapboard Siding for an Energy-Efficient Island Remodel
JLC visits the job site on Peaks Island, Maine, to see carpenters apply a... More
Securing Rainscreen Siding
Test results show how to properly install clapboards and vertical strapping over... More
View All >
Board Siding Instruction
The Case of the Sobbing Siding
On a callback for a siding leak, a building inspector discovers that his roof... More
Repainting Aluminum Siding
Q: Does faded aluminum siding with a chalklike residue on the surface require any special preparation before repainting? More
Q&A: Extractive Bleeding on Cedar Siding
Q. I recently installed 20,000 square feet of 1/2x4-inch cedar siding, rough side out, on a project in Connecticut. The exterior wall construction was 6-inch metal steel studs sheathed with 5/8-inch exterior plywood and covered with building wrap. Inside, More
Q&A: Caulking Siding — or Not?
Q. When installing cedar clapboard, should gaps between the siding and trim be caulked? More
Q&A: Ventilating a Rain Screen
Q: I plan to install clapboard siding using the rain screen method. The siding will be fastened to 3/4-inch vertical battens, nailed over each stud. At the top, I plan to ventilate the rain screen into the soffit area. What is the best detail to ventilate More
View All >
