Exterior Caulks and Sealants
JLC Field Guide: Exterior Caulks and Sealants
A well-detailed exterior should rely on drainable wall assembly, not on caulk. However, caulks and sealants are essential to the assembly. Proper selection and joint design will ensure lasting performance.
Learn More
Air-Sealing Retrofit for a Chimney Chase
While they have the roof open, a weatherizing crew takes advantage of easy access... More
Retrofitting New Windows In An Older House – Part 1
Replacing windows with new units in winter requires super-efficiency to limit the... More
View All >
Exterior Caulks and Sealants Instruction
New Ultimate Sealant – OSI Quad Max
Quad Max looks to be the ultimate sealant for any weather and any jobsite... More
Gluing Exterior Trim
Q: When installing stained vertical cedar siding or fascia trim, what type of glue should be used for splices and corners? Some contractors like to dab a little stain on the cut ends of 3-degree splices or on 4-degree corner miters, but is there an exteri More
View All >
