Exterior Finishes
JLC Field Guide: Exterior Finishes
The durability of any exterior finish, be it a paint, stain or clear finish, often comes down to how well drainable the cladding is and how well you prep the surface.
Learn More
Exterior Finishes Featured Articles
Lead-Safe Paint Removal
Choosing the right tool can make a nasty job easier and safer. More
Paintbrushes
Paintbrushes
Pro Tips for Choosing, Using, and Cleaning More
Painting the Coastal Home
Exterior paint takes a beating from intense sun and salt spray, and the demands of More
Mixing Materials for Exterior Trim
Using PVC and wood on the same door More
Synthetic Stucco Without Failures
To avoid a lawsuit, build a drainable assembly. More
Stain-Grade Finishing On Site
Use premium materials and a methodical approach to achieve a cabinet-grade finish. More
View All >
Exterior Finishes Instruction
Exterior Paints vs. Stains
Glossy vs. Flat
Glossy vs. Flat
Which type should you choose in an exterior paint? More
OCD Sandpaper
Refinishing a Hail-Damaged Home
While time consuming and costly, the surface restoration was still significantly... More
The Best Way to Finish an Exterior Wooden Door
Exterior doors take a beating from both frequent use and the elements. Here's how to provide a lasting clear finish on an exterior door. More
View All >
