Fiber-Cement Siding
JLC Field Guide: Fiber-Cement Siding
Fiber-cement siding is dimensionally stable, holds paint well and, unlike wood and wood-composites, won’t cup, shrink, or swell.
Learn more
Fiber-Cement Siding Featured Articles
Installing Fiber-Cement Siding
Fiber-cement siding is no fun to cut and handle, but its price and durability make... More
Getting Kickout Flashings Right
Leaks are a liability. It's so much easier and less expensive to invest in $15... More
Common Siding Failures
Avoid errors that will cause a fiber-cement job to fail More
Rainscreen Clapboard Siding for an Energy-Efficient Island Remodel
JLC visits the job site on Peaks Island, Maine, to see carpenters apply a... More
View All >
Fiber-Cement Siding Instruction
The Case of the Sobbing Siding
On a callback for a siding leak, a building inspector discovers that his roof... More
Do Fiber-Cement Butt Joints Have to Be Caulked?
Q: The clients on an upcoming project are interested in installing fiber-cement... More
Q&A: Caulking Siding — or Not?
Q. When installing cedar clapboard, should gaps between the siding and trim be caulked? More
Q&A: Ventilating a Rain Screen
Q: I plan to install clapboard siding using the rain screen method. The siding will be fastened to 3/4-inch vertical battens, nailed over each stud. At the top, I plan to ventilate the rain screen into the soffit area. What is the best detail to ventilate More
Q&A: Backpriming Siding
Q: I have often read that wood siding should be backprimed before installation. But I believe that a primer without a finish coat is of no value, because I don’t think a primer can slow down moisture movement. Has there been any research or testing on thi More
View All >
