A.If the existing glue is contact cement (which is typical), then I would recommend using that. Just apply a generous amount of contact cement to both surfaces and allow it to dry, then press back into place. If wood glue was used, spread water-based wood glue in the lifted area and add pressure for a couple of hours or until the glue is dry.
— M.R.
