With safety gear on, surface ready, and surroundings protected, I was ready to start applying the material. Relying on my test-patch results, I sprayed the Peel-Away on heavily and evenly, about 1/8 to 1/4 inch thick, depending on the thickness of the paint layers. To get an even coat, it's necessary to direct the spray pattern perpendicular to the surface to be coated. This wasn't difficult when coating flat surfaces, but it got trickier when it came to the multi-surfaced decorative trim pieces and turned spindles, since the sprayed material won't go around corners. When necessary, we'd apply the compound with a brush, trowel, or even a rubber-gloved hand. At this juncture, it helped to have an assistant or two to keep the process going, because the special paper provided with the Peel-Away system has to be applied over the wetted surface. One side of the paper is plastic-laminated to prevent the stripping compound from drying out while it's working. The paper has to be applied with the plastic side out, and be embedded in the material, avoiding trapped air bubbles as much as possible (Figure 5). Trapped air can promote failure by allowing the compound to dry on the surface.
