Weather Barriers and Flashing
Proper installation of a water-resistive barrier, or WRB—preferably with a rainscreen behind the siding—enables us to build resilient homes that will last for generations.
Learn More
Weather Barriers and Flashing Featured Articles
Common Callbacks
What are the building blunders you see most often?  Whether it's in exterior,... More
Flashing Tips To Avoid Window Leak Paths
Windows are one of the most vulnerable areas to water and air leaks. More
Brought to you by Zip System® Sheathing and Tape
Working with Flexible Flashing
If you need to make a custom window or door sill pan, or flash a pipe, wire, or... More
A Primer on Water Management
Strategies for dealing with water both around and on a home More
Sheathing Damage From Using Wide, Impermeable Flashing
In cold climates,wide, impermeable flashing can inhibit drying, leading to some... More
Fluid-Applied Window Flashing
As close to foolproof as it gets for recessed openings and other complex flashing... More
View All >
Weather Barriers and Flashing Instruction
Proper Width of Window Flashing Tape
It can be tricky to determine a minimum width when the window manufacturer refers to the code or the flashing-tape instructions, and the flashing-tape instructions and the code both refer you back to the window manufacturer or flashing-tape instructions. More
Best-Practice Apron Flashing
For a more-effective and better-looking result, integrate the exposed apron with... More
New Ultimate Sealant – OSI Quad Max
Quad Max looks to be the ultimate sealant for any weather and any jobsite... More
View All >
