Windows and Doors
JLC Field Guide: Windows and Doors
Quality windows and doors can increase comfort and home value more than almost any other exterior feature. But the impacts on building performance can be harsh if you don't get the water, air and thermal detailing right.
Learn More
Windows and Doors Featured Articles
Rx For Wood Windows - Preventing Paint Failure
To prevent paint failure, make sure wood windows are properly flashed, prepped,... More
Installing Full-Frame Replacement Windows
A window and door specialist from Chicago shares fast and efficient installation... More
ProVia Steel Doors—Stronger By Design
Your homeowner customers can go to any Big Box store and choose a steel door... More
Brought to you by ProVia
Replacing Basement Windows
Leaky Basement Windows
Flashing Recessed Windows
Lessons in how to avoid costly mistakes when waterproofing complex window openings More
View All >
Windows and Doors Instruction
Casing Windows in Deep Wells
Recessed Windows – A Foolproof Install Method
Fixing Ghost Doors
There's nothing supernatural about it. More
Working with Flexible Flashing
If you need to make a custom window or door sill pan, or flash a pipe, wire, or... More
The Best Way to Finish an Exterior Wooden Door
Exterior doors take a beating from both frequent use and the elements. Here's how to provide a lasting clear finish on an exterior door. More
View All >
