Concrete Block
JLC Field Guide: Concrete Block
Foundations built with concrete block may cost less than poured concrete, depending on local material and labor costs. Block may also be more practical than poured concrete for small jobs, crawlspace foundations, or jobs where access by concrete trucks is limited.  Block foundation performance depends on proper design and detailing. Effective perimeter drainage is a necessity to reduce lateral soil pressures, especially for full basements. Block is also very porous, so waterproofing or dampproofing is usually required to control moisture intrusion.
Learn more
Concrete Block Featured Articles
Building A Block Foundation
Instead of subcontracting the work, invest in a few masonry tools and put your own... More
Building a Reinforced Concrete Block Wall
A mason describes how he detailed a pair of large block walls to carry severe... More
Block Foundations for Small Additions
If your crew has the skill and you own the right equipment, it may make sense to lay your own masonry foundations. More
Small Garage Foundation Repair
A mobile concrete mixer solved both budgetary and logistical problems More
Concrete Houses for the Coast
Hurricane Katrina taught a valuable lesson: the only houses likely to survive the... More
High and Dry
High and Dry
In the flood-prone Gulf region, an elevated home is a no-brainer. The classic... More
View All >
Concrete Block Instruction
Concrete Block Concrete Block
For block foundations, effective perimeter drainage is critical to reduce lateral soil pressures, especially for full basements (see Perimeter Foundation Drains). And block is also very porous, so waterproofing or dampproofing is important to control moisture intrusion (see Waterproofing and Dampproofing). More
Framing Fix for a Faulty Foundation
A foundation that is out-of-level and out-of-square can be fixed by shimming the... More
Block Walls, Vapor Barriers, and Solar Vapor Drive
Q: With a cavity wall assembly consisting of load-bearing 8-inch CMUs (concrete masonry units), 2 inches of rigid foam, a 2-inch air space, and 4-inch concrete bricks covered with cementitious stucco and an acrylic color coat, how important is dampproofin More
Retrofitting a Window Into a Block Foundation
Q: I need to install a basement egress window in a concrete-block foundation wall.... More
Q&A: Tying Into Concrete Block
Q: What is the best way to tie a new block addition into an existing block building? More
View All >
