Insulated Foundation Systems
JLC Field Guide: Insulating Foundations
Below-grade heat loss can be significant in colder climates. And as with any structure in the ground, you also have pay close attention to water and moisture issues. But the marriage of moisture and insulation is not always a happy one.
Learn More
Building to Ledge with Foam Forms
Foam-core blocks offered the cheapest way to build this 17-sided foundation on solid rock. More
First Time Out With ICFs
Foam forms can save time and money while providing a superior finished product.... More
Fast Precast Foundations
A Superior Wall foundation has as much strength as a poured foundation, plus it’s... More
Cost-Saving Insulated Foundations
Reduced excavation and forming time make ICFs a cost-effective way to build a... More
Beyond the Basics With ICFs
Curved walls and arch-topped openings are possible with standard blocks. More
Insulated Foundation Systems Instruction
Calculating FPSF Insulation Requirements
There are two good sources for designing frost-protected shallow foundations (FPSFs). More
On the Job: ICF Retaining Wall
ICF retaining wall; no-sweat plumbing; overhead lift trailer More
Waterproofing ICFs
Q. Is there a spray-on waterproofing that's compatible with ICF foundations ? that won't "melt" the polystyrene? More
View All >
