Pier Foundations
JLC Field Guide: Pier Foundations
Pier-and-grade-beam foundations can be as simple as a sonotube foundation for a porch or small addition, or as complex as an engineered foundation for expansive soils.
Learn more
Pier Foundations Featured Articles
Working With Helical Piers
Engineered steel piles are an affordable foundation option for small jobs and... More
Slideshow - On Site with Diamond Pier
Coastal Connection travels to Provincetown, Mass., to see a contractor make quick... More
Pier-and-Beam Foundations
For problem soils, there’s no better foundation type, but you better get the... More
Floating a Boathouse
Working underwater raises a landmark above water More
A Pier-and-Beam Foundation For a Coastal Site
Where unstable soil and periodic tidal flooding are a concern, helical piers... More
View All >
Sizing Deck Piers
Fast, Accurate, and Attractive Piers
Square wood forms knocked together from scrap lumber put piers in the right place... More
Helical Pile Foundations
Contractors weigh in on the advantages of helical piles over concrete tubes,in... More
Working With Sonotubes
Every porch or deck I build starts with level footings and solid, plumb concrete... More
Q&A: Sinking Foundation
Q. I'm looking at a wood frame house with a block foundation that is settling. The basement wall sits on a 20-inch-wide concrete footing, but someone later poured a concrete brick shelf from footing to grade and then put brick veneer siding on the house. More
View All >
