Poured Walls
JLC Field Guide: Poured Walls
Concrete is a strong material and pouted foundation walls easily support downward compressive loads. It's the lateral loads that are the real controlling factor.
Learn More
Poured Walls Featured Articles
Designing Concrete Basement Walls
An engineer explains how wall thickness, rebar, and proper drainage all affect the ability of poured concrete foundation walls to resist lateral soil pressure. More
Creating a New Foundation for an Old House
Lifting and resupporting an early-1800s home on a tight site. More
Stepped Buttresses for a Row House Basement
As part of a major gut-renovation project on a historic Brooklyn row house,... More
Small Garage Foundation Repair
A mobile concrete mixer solved both budgetary and logistical problems More
View All >
Poured Walls Instruction
Concrete for an ICF Foundation
ICF wall defects are usually caused by poor placement practices. But the right... More
Concrete Cracks – How To Fix
Matt Risinger tackles cosmetic repairs to a polished concrete slab, using an epoxy repair to render unsightly cracks nearly invisible. More
Creating a Bollard
What are the engineering requirements for a bollard in a residential garage? More
Q&A: Retrofitting a Walk-Out Basement
How do you protect the footing and foundation from frost in a very cold climate... More
Ancient Roman Concrete Has Lessons for Modern Scientists
Built more than two thousand years ago, the concrete seaport facilities of ancient... More
View All >
