A.Christopher DeBlois, P.E., an engineer with Palmer Engineering in Chamblee, Ga., responds: Whenever there is a design alternative, I generally recommend against bolting a deck ledger board to brick veneer. I prefer to provide independent support adjacent to the house, usually with posts and beams. In many cases that is impractical or undesirable, however, so the deck gets bolted to the house.
The brick veneer on a house typically supports its own weight and nothing else. The section of the CABO One & Two Family Dwelling Code on lintels states that “masonry veneer shall not support any vertical loads other than the dead load of the veneer above.” When independent support is provided against the house to support the deck, standard...
