A.A lot depends upon what kind of reinforcement you need.
Polypropylene fibers can help reduce the initial shrinkage which occurs in concrete during the first two days of curing. But these fibers do not permit wider spacing of control joints over what is specified for unreinforced concrete. If the concrete does crack, the fibers will not hold the pieces in alignment as well as welded wire mesh. The...
