A. A concrete footing should rest on undisturbed inorganic soil. The crushed stone could cause settling of the footing. Moisture rising through the footing shouldn’t be a great problem if you have adequate perimeter drainage. As a failsafe, you might install a waterproofing membrane between the footing and the foundation. W.R. Meadows (wrmeadows.com) sells a line of asphaltic membranes for this purpose.
