Structural Slabs
JLC Field Guide: Structural Slabs
Slab-on-grade foundations are one of the most common foundations in the U.S. becasue they can be adapted to perform well in a wide range of climate zones and difficult soil conditions.
Learn More
Structural Slabs Featured Articles
Pouring a Structural Slab
An East Coast builder describes the process of forming and pouring a structural garage slab using polystyrene deck forms. More
Post-Tensioned Slabs
Expansive soils can wreak havoc on conventional wire-mesh reinforced slabs. A... More
Small Garage Foundation Repair
A mobile concrete mixer solved both budgetary and logistical problems More
Replacing a Slab Foundation
When the original builder flubs a foundation, someone else has to clean up the mess. More
Super-Insulated Slab Foundations
Compacted drainage stone and a thick layer of foam prevent frost damage and keep... More
View All >
Structural Slabs Instruction
Concrete Cracks – How To Fix
Matt Risinger tackles cosmetic repairs to a polished concrete slab, using an epoxy repair to render unsightly cracks nearly invisible. More
Insulating Outside the Foundation
Best practices for insulating a foundation. More
Basement Stairs Transplant
Stacking the basement stairs under the stairs to the second floor opens up the... More
Q&A: The Best Way to Repair a Hole in a Concrete Slab Before Tiling Over?
Michael Byrne, a veteran tile installer and consultant, explains two scenarios:... More
Troweling Air-Entrained Concrete
Can hard-troweling air-entrained concrete lead to delaminations? More
View All >
