Waterproofing and Dampproofing
Dampproofing is a water-resistant coating designed to shed water and resist soil moisture. It's the default for any poured concrete wall below grade. But on sites with slow-draining soils or high water tables, or where site drainage is unreliable, a waterproofing system designed to resist water under hydrostatic pressure will be needed.
Learn More
Waterproofing and Dampproofing Featured Articles
Waterproofing Basement Walls
We survey the major types of foundation waterproofing, from spray-on to peel-and-stick membranes. More
Practical Foundation Waterproofing
Combined with a working drain, this new type of plastic membrane keeps groundwater out of the foundation while allowing moisture in the concrete to evaporate to the outside. Here’s how it’s installed. More
A Basement Floor Without Concrete
With the right prep work, a double layer of OSB might be better than a slab More
A Case Study in Foundation Waterproofing Failure
The house wasn't even done and already the basement had become a wet mess. More
Lowering a Basement Floor
Gaining an extra foot of headroom isn’t easy, but it can yield valuable living space. More
View All >
Waterproofing and Dampproofing Instruction
Cold Weather-Concreting
Cool temperatures can reduce concrete strength unless precautions are taken. Here are the products and techniques that guarantee a successful pour — even when it’s below freezing. More
Q&A: Preventing Cracks in Concrete Slabs
Q: The Journal’s panel of experts answers the most commonly asked questions from... More
Ceramic Tile Troubleshooting
The most common tile callbacks and how to avoid them. More
Restoration Primer: Drying Up Wet Basements
Drying up wet basements More
View All >
