Dimensional Lumber Floors
New Joists for an Old Floor
The best remedy for a sagging out-of-level floor is putting in new LVL joists and... More
Framing Over a Complex Foundation, Part II
This follow-up article to "Mudsill Layout for a Complex Foundation" describes... More
A Flush-Framed Floor to Maximize Space
Eliminating a dropped beam and a brick pier in a basement remodel required the use... More
When it comes to laying out a complex foundation, attention to detail makes the... More
Brooklyn Townhouse Makeover: Reinforcing the Floor
Engineered beams, steel joists, and flitch plates help bring a 19th-century... More
View All >
Dimensional Lumber Floors Instruction
Flush-Framed Floor Joists
Install joists higher than the girder to accommodate shrinkage. More
Mudsills and Out-of-Level Foundations
Recently we contracted to do a house with precast foundation walls that were set out of level - up to 3/4 inch over 30 feet, in some places. What's the best way to shim and air-seal the mudsill? More
Q&A: Long-Span Floor Joists
Q. Would floor trusses or wood I-joists be stronger over a 26-foot span? More
Q&A: Plumbing Around Floor Trusses
Q: We’re installing a fiberglass tub unit over a truss-framed floor. A small plan... More
Q&A: Purpose of T&G Plywood
Q: Does tongue-and-groove plywood add extra strength or stiffness to a floor... More
View All >
