Engineered Lumber Roofs
Roof Framing with Wood I-Joists
When wood I-joists are used as rafters, connections at the structural ridge and... More
Custom Tapered LVL Roof Rafters
Framing a Supporting Valley
The trick is keeping clean ceiling lines above a vaulted space. More
Framing a Hip Roof
Framing a Hip Roof
For a perfect fit, pay attention to how the roof will be stacked when calculating... More
Engineered Lumber Roofs Instruction
Working With Large Beams
Tips for planning and equipment that will make working with large glulam or other... More
Modifying Roof Trusses
My client wants to add a 16-inch-wide 4-inch-deep tray ceiling in a room where the drywall ceiling is attached to the bottom chord of roof trusses. To do this, I'd have to cut out and raise the bottom chords of the trusses. Is that possible? More
Rafter Ties and Shallow-Pitch Roofs
Q. My clients have a garage with a conventionally framed 4/12 roof that they want... More
Snow Loads on Roofs
Snow Loads on Roofs
Q: I've always thought that building codes leave a pretty generous margin for... More
Sizing the Birdsmouth
Q: When laying out the seat and heel cuts on a rafter, how large should the notch be? More
View All >
