Framing Connectors
JLC Field Guide: Framing Connectors
Whether it's a standard stick-frame or one that needs to resist seismic forces or high winds, making strong, engineered connections requires a range of framing connectors. The purpose of these connectors is to strengthen the tie between different structural members and ensure an unbroken load path.
Learn More
Framing Connectors Featured Articles
Practical Engineering: Using Metal Connectors
Making strong attachments with metal connectors More
Top Ten Code Violations
Pay close attention to these to avoid failing inspections More
DUC Undercut Anchors Installation Guide
A concrete anchor system with a mechanical connection—not a friction-fit. More
Brought to you by MiTek
Framing Hardware Dos and Don'ts
Prevent structural problems and failed inspections by avoiding these common... More
View All >
Framing Connectors Instruction
Common Errors With Framing Connectors
Joist Hanger Fasteners
Q&A: Nailing Tips for Advanced Framing
Q: I can see the value in advanced framing in terms of reduced thermal bridging, better insulation, and savings in framing lumber. But I've hesitated to get serious about it because I worry that the absence of some familiar framing member is going to make More
Metal Connectors and Galvanized Coatings
Can standard galvanized Simpson STHD strap-tie hold-downs be used in contact with... More
Wall Bracing Revisited
View All >
