Roof Trusses
JLC Field Guide: Roof Trusses
Roofs framed with trusses are engineered systems that demand careful installation and bracing. Any changes in bearing or loading to the original plan, or any field modifications to trusses, needs an engineer's approval.
Learn More
Roof Trusses Featured Articles
Truss Roofs Production Style
A California production framer shows how on-the-ground prep work, precut braces... More
Creating an OSHA-Compliant Safety Program for a Homebuilding Construction Site
After a visit from OSHA, a design-build contractor learns how to do things by the... More
Roof Truss Repair
Field repairs should always be designed by an engineer More
Installing Gable Roof Trusses
On-the-ground layout and efficient use of a crane enable these Rhode Island builders to place, brace, and sheathe a truss roof in one day. More
How to Safely Frame a Roof on the Ground
To eliminate the danger and discomfort of framing and shingling a roof, Lee... More
Raising the Pitch of an Existing Roof
By combining trusses with stick framing, the author was able to frame a new roof... More
Gable-End Retrofits
Gable-End Retrofits
A couple of decades ago, not much was typically done to secure gable-end trusses:... More
View All >
Roof Trusses Instruction
Deep Rafters for a Massachusetts Passive House
The massive ridge beam and deep I-joist rafters in this custom Passive House aren’... More
Slideshow: Framing a Loft
Coastal Connection follows the action as Cape Cod contractor Mike Hill frames the... More
Maine Passive House: Framing Overhangs
Work continues on the high-performance Maine ski lodge addition under construction... More
Flipping the Script on a Second-Story Addition
Design-builder Andrew DiGiammo tries a new strategy: Build the new roof first,... More
Strapping Ceilings
Strapping Ceilings
Strapping serves many purposes both for framers, as well as for many of the subs... More
View All >
