Seismic and Wind
Lateral-Force Collectors for Seismic and Wind-Resistant Framing
There's more to wind- and earthquake-resistant framing than properly constructed shear walls. A veteran structural engineer describes the key connections that collect and control potentially catastrophic loads. More
A Texas Tornado: Lessons Learned
Stronger Connections Could Have Saved Homes More
A Practical Guide to Building in Seismic Zones
Steel and framing hardware requirements demand a whole new approach to foundation... More
Portal Frame Holdown Rules Revised
The “portal frame” method for bracing walls against wind and earthquake is still... More
Seismic and Wind Instruction
Narrow Shear-Wall Solution
Q. I'm the project manager for a construction company that's building a series of... More
Strengthening Garage Door Walls
Q. Can anyone explain the actual technical concern and reason that new building... More
Seismic & High-Wind Framing
Shear walls * Hold-downs * Foundation anchors * Hardware layout * Retrofitting seismic connectors & shear walls * Nailing shear panels * Wood-to-wood and wood-to-masonry roof connections * Roof diaphragm details More
