The Common Code Violations Survey, published by NAHB and ICC in 2013, asked building officials nationwide to rank violations in 16 different categories. The responses were too many to include here, so we have listed the top three in each category. They’re in descending order, with the most common violation at the top. Use this as a checklist when preparing for an inspection or, better yet, download the report (PDF) to see the full list for each category.
Grading and Site Drainage
  • Erosion control measures not in place
  • Grading
  • Downspouts/ drainage controls
Foundation
  • Improper reinforcement or support of rebar
  • Standing water/mud in footing or on rebar
  • Improper anchor bolts
Wall Framing
  • Missing fire-blocking
  • Stud cut or notched to an impermissible depth
  • Missing hold-downs, straps, etc.
Floor Framing
  • Notches in areas not permitted
  • Missing anchor bolts
  • Sheathing nails missing joist
Trusses
  • Bracing not installed
  • Improperly connected to wall plate
  • Impermissible alteration leading to additional load
Roofing
  • Missing nails or fasteners
  • Over-driving of nails through shingles
  • Absence of felt, or incorrect type
Windows and Doors
  • Improper flashing
  • Inadequate fire rating
  • Improper door weather-stripping
Handrail
  • Improper height or spacing
  • Improper graspable surface
  • Missing handrails
Guardrail
  • Guardrail opening too large
  • Height criteria not met
  • Not properly fastened or installed
Stairs
  • Stair rise and run violations
  • Stair headroom
  • Improper stair construction
Plumbing
  • Improper notching or boring of framing
  • Missing or improper nail plates
  • Pipes improperly supported
Mechanical
  • Inadequate combustion air or makeup air
  • Inadequate clearance to combustibles
Electrical
  • Grounding issue
  • Labeling of circuits
  • GFCI Protection
Energy
  • Improper sealing of penetrations through exterior walls
  • Improper duct sealing
  • Improper installation of insulation around wiring and plumbing passing through stud cavity
Decks
  • Improper or inadequate ledger connection to house
  • Improper guardrail or handrail installation
  • Deck does not conform to approved plans
Life Safety
  • Failure to install correct glazing in required hazardous locations
  • Inadequate egress
  • Improper installation of smoke detectors
For more on common code violations, see "Top Ten Code Violations."
