Wall Framing
JLC Field Guide: Wall Framing
Wall frames play an obviously critical role in supporting roofs and floors. Stud spacing and top plate overlaps clearly effect the strength, but the rules change when wall heights grow taller.
Learn More
Wall Framing Featured Articles
Plumbing and Straightening Walls
This quick, accurate method prevents problems with the framing and finishes that... More
Building With Cross Laminated Timber
The solid CLT panels simplify making the building envelope airtight, and they help... More
Gable-End Retrofits
Gable-End Retrofits
A couple of decades ago, not much was typically done to secure gable-end trusses:... More
Retrofit Moment Frames
In California, cities are requiring moment frames on ‘soft story’ openings More
Efficient Framing
Efficient Framing
Notes on how one crew chief organizes the framing process More
Fire Separation Walls
These code-required assemblies can complicate construction, but they can also help... More
View All >
Attaching Floor Framing to SIPS
Building and Raising Exterior Walls
One crew’s methods for running an efficient job More
Better Corner Nailing for Drywall
This detail provides better nailing for drywall and access to insulate wall corners. More
View All >
