Air Conditioning
Air Conditioning for Humid Climates
Balancing cooling with humidity control is a tough job in the coastal South. A... More
Sizing Air Conditioners
To avoid callbacks, many hvac subs size air conditioners using methods that inflate the cooling load. The result is an oversized unit that cools the air, but operates inefficiently and does a poor job of reducing indoor humidity. Three energy engineers explain how to achieve proper cooling without oversizing. More
Chilling at Home
Ductless mini-splits offer efficient cooling and outstanding dehumidification,... More
Ductless Heat Pumps
These easily installed units offer flexible sizing and high efficiency at moderate... More
Conditioning Energy Recovery Ventilators
Adding a heat pump lets an ERV help with heating, cooling, and humidity control. More
Heat Pumps, Heat Pumps, and More Heat Pumps
Heat pumps were the hot topic at last week’s Building Energy 14 conference, hosted... More
Slideshow: Brooklyn Passive House Mechanicals
Here’s a sneak peek at the Mitsubishi ducted mini-split heat pump and Zehnder energy recovery ventilator roughed-in at a Brooklyn, New York, passive house retrofit we’ve been following. More
Air Conditioning Instruction
Commissioning a Ventilation System
Commissioning is not a word we hear much in residential construction, but it's a... More
Panned Bays
Is it OK to use a joist bay for a return-air plenum in an HVAC system? More
Solving for Comfort With a 'Smart' Thermostat
Tracking temperature, humidity, set point, and equipment runtime can uncover the... More
Installing an ERV in a Two-Family Passive House
JLC’s Coastal Connection goes on site in Boston, Mass., where Placetailor is... More
Rookie Builder Mistakes - Part 2 - HVAC
Let’s start with some obvious mistakes that aren’t even visible to most builders... More
View All >
