Forced-Air Systems
Trouble-Free Forced-Air Heat
An hvac contractor explains how to size, select, and install furnaces and ductwork to ensure quiet, efficient, and even heating. More
Adding On to Forced Hot Air
Heating an addition may require adding hot air ducts. But does the existing furnace have enough capacity to handle them? Here’s how to find out. More
Fine-Tuning Forced-Hot Air
A heating contractor details how to upgrade from a typical bare-bones heating... More
Conditioning Energy Recovery Ventilators
Adding a heat pump lets an ERV help with heating, cooling, and humidity control. More
Zoning Forced-Air Heating Systems
An hvac contractor shows how he uses advanced controls and motorized dampers to provide balanced zone control in forced-air heating systems, in both retrofits and new installations. More
Forced-Air Systems Instruction
A New Roof Poisons a Family
Though at first the culprit appeared to be the furnace, it turned out that the... More
Panned Bays
Is it OK to use a joist bay for a return-air plenum in an HVAC system? More
Solving for Comfort With a 'Smart' Thermostat
Tracking temperature, humidity, set point, and equipment runtime can uncover the... More
Comparing Propane and Oil
Q. Which home heating fuel is usually cheaper, oil or propane? More
Q&A: One Furnace or Two?
Q: What factors must be considered when deciding whether to use a large hot-air furnace with two zones or two smaller furnaces? More
