Hydronic Heating
Hydronic Heating for Low-Load Houses
With the right hardware and layout, hot-water heating saves energy and makes ideal... More
Hydronic Baseboard Basics
Finned-tube baseboard is the most commonly installed hot-water heating system in... More
Piping Layouts for Hydronic Heat
The design of hydronic heat distribution piping affects overall comfort levels, regardless of boiler efficiency. An engineer describes the pros and cons of four piping layouts for hot-water heat. More
Hydronic Radiant Heat for Wood-Framed Floors
You don’t need to pour a concrete slab to get the benefits of radiant heat. An engineer describes new approaches that combine radiant heating with conventional floors. More
Installing a Radiant Wall
Sometimes heavy floor coverings, furniture, or built-ins reduce the area available for radiant heating. This heating specialist shows how to turn walls and ceilings into heat emitters. More
View All >
Hydronic Heating Instruction
Solving for Comfort With a 'Smart' Thermostat
Tracking temperature, humidity, set point, and equipment runtime can uncover the... More
Q&A: Closing a House for the Winter
I have customers who wants me to build a log home that will be used seasonally, for about two months of the summer and another two months in the winter. During the rest of the year they want to leave the house closed up and unheated. We're at the edge of the Rocky Mountain Front Range in eastern British Columbia, and winter temperatures often fall to 20F. I've discouraged the clients from installing a hydronic heating system because of the difficulty of draining it twice a year (draining the domestic water will be headache enough), but what other potential problems should I be thinking about? I'm concerned that the radical swings in temperature could damage interior finishes More
Insulating a Radiant Slab
How much insulation is necessary under a typical basement radiant slab? More
New Slab Over Old?
Q. I am renovating a barn where the existing concrete floor slopes approximately 6 inches in 30 feet. The architect wants me to build a level floor using wood sleepers with foam insulation in between, then pour a minimum 11/2-inch-thick radiant slab betwe More
Comparing Propane and Oil
Q. Which home heating fuel is usually cheaper, oil or propane? More
View All >
