Air Sealing
JLC Field Guide: Air Sealing
Sealing potential leaks in the building envelope is an essential step in building a durable, energy-efficient structure. It’s easy to focus on insulation, but without careful air-sealing, insulation is all but useless.
Learn More
Air-Sealing Without Foam
Tape is best, but the right caulk can also provide a tough, reliable seal More
An Air-Sealing Priority List
To cost-effectively meet air-sealing requirements for new construction, some leaks... More
Thermal Imaging With a Blower Door
Though it's impossible to seal every hole in an existing building to prevent air... More
Air-Sealing for Hot Climates
Excluding heat and humidity saves energy, improves comfort, and increases durability More
Fixing the Bonus Room
A room over the garage shouldn’t always be a warranty issue More
Airtight New Homes: Top Trouble Spots
Air-Sealing Options: Good, Better, Best
New standards for air-sealing require a range of new materials and methods More
View All >
Air Sealing Instruction
High-Performance Energy Details for 2x4 Walls
Here’s a new resource for high-performance building and design professionals. More
Delta Vent SA Review
This breathable peel & stick membrane serves as a weather & air barrier all in one. More
Tight House Construction - Sealing Exterior Sheathing Seams
In my quest to build ever tighter houses I've decided that my goal is for every... More
The Best Air-Sealing Tips and Tricks for Homebuilding and Remodeling
Use specialized tools and materials and a methodical approach. More
Attic Insulation for Hot Climates?
Q: Builders in cold climates often go beyond code-required attic insulation levels... More
View All >
