Cavity Fill
Installing Dense-Pack Cellulose
This economical material both air-seals and insulates More
Tightening Up a Two-Family House
Chasing down and fixing energy leaks in an old house can be tricky and expensive,... More
Getting Quality From Fiberglass Insulation
To get the most from fiberglass batts, you have to start thinking about insulation at the framing stage and coordinate with other subcontractors. An insulation contractor explains. More
Island House Makeover — Insulating the Skin
In the teeth of a record-breaking winter, Thompson Johnson Woodworking wraps the... More
Adding an Insulated Envelope
An airtight "puff jacket" achieves near Passive House levels. More
Wrapping an Old House in a Passive House Puffy Jacket
Mid-coast Maine builders EcoCor, Inc., are applying their characteristic insulated wood I-joist exterior wall system package to an existing old house. More
Cavity Fill Instruction
Creating a Palette of Foam-Free Superinsulation Details
There’s more than one way to build a highly insulated, air-tight house—or to tighten up and super-insulate an existing home. Here’s a look at an evolving array of superinsulated details that don’t use spray foam. More
Working With Roxul Insulation
Choosing insulation for a high-performance home in Northern Vermont requires... More
Reusing Loose-Fill Cellulose
Working around existing attic insulation to seal air leaks may be more cost-effective than removing and replacing it More
Fire Retardant in Spray Foam
Is it a potential health hazard? More
Can Fiberglass Batts Perform Well in Tightly Sealed Houses?
I understand that fiberglass batt insulation can allow air to move through it and that this air movement degrades the insulation's R-value. Two causes I've heard about are wind-washing at the eaves and convective loops that can start in a wall cavity on really cold days and wick warmth from inside to the outside wall surface. But recently I have taken pains to do a very good air-sealing job on everything I build, whether it's an addition or a new house. I'm getting blower-door readings of less than 1.5 air changes per hour at 50 pascals. I also use baffles at the eaves, and seal the sheathing to the framing before insulating. Under these conditions - with air movement cut to a minimum - will fiberglass insulation perform at its stated R-value? More
View All >
