Conditioning Crawlspaces
JLC Field Guide: Conditioning Crawlspaces
Sealing and insulating a crawlspace will save energy and reduce the chance of mold and mildew compared to a vented crawl—but only if the builder uses careful air sealing and climate-appropriate insulation.
Sealing a South Carolina Crawlspace
Coastal Connection visits the job site with specialty contractor Energy One... More
Venting the Crawlspace
Most crawlspaces are vented to the outdoors, but encapsulating the crawlspace has... More
Seal Seams In Crawlspace Liners
The crawlspace of a home was consistently wet — in spite of the 6-mil poly liner.... More
Fixing a Wet Crawlspace
A crawlspace expert describes how he turned a damp bug- and mold-infested... More
View All >
Conditioning Crawlspaces Instruction
LVLs Rotting in Crawlspaces
Q. Many homes in the Dallas area are built on crawlspaces and use LVL beams. Most of these homes have dirt floors but are built to code with regard to crawlspace ventilation. In many cases, I'm finding that the engineered wood is rotting at the point wher More
Best Flooring for a Humid Climate
Q: I'm planning on installing laminate flooring on the first floor of my North... More
Q&A: Crawlspace Insulation
Q: I am building an addition over a 30-inch-high crawlspace. The local inspector has approved my plan to build a sealed crawlspace without ventilation. Should I install rigid foam insulation on the interior of the block walls, or should I insulate between More
Q&A: Drying Out a Damp Crawlspace
Q: To dry out damp crawlspaces in Virginia, I have had success closing the crawlspace vents and installing a dehumidifier. Are there any other measures I could be taking? What is an appropriate relative humidity level for a crawlspace? More
Q&A: Leaving Rigid Foam Exposed in Crawlspace
Q: I plan to install rigid foam insulation in a crawlspace. As far as I know, most types of rigid foam insulation can’t be left exposed but need to be covered with a layer of drywall for fire resistance. Is there a type of rigid foam insulation panel avai More
View All >
