Continuous Exterior
Continuous Exterior Featured Articles
Air-Sealing and Insulating a High-Performance Shell
Take pains to seal all possible leaks, then run a blower-door test before insulating. More
Building a High-Performance Shell for a House
Advanced framing and exterior foam reduce conductive heat loss and provide good air-sealing opportunities. More
Retrofitting Exterior Insulation
Adding rigid foam to the outside of the shell dramatically increases R-value while... More
Working With Thick Layers of Exterior Insulation
JLC editor Clayton DeKorne reviews the latest Department of Energy guidelines on... More
Island House Makeover — Insulating the Skin
In the teeth of a record-breaking winter, Thompson Johnson Woodworking wraps the... More
Wrapping an Old House in a Passive House Puffy Jacket
Mid-coast Maine builders EcoCor, Inc., are applying their characteristic insulated wood I-joist exterior wall system package to an existing old house. More
View All >
Continuous Exterior Instruction
Creating a Palette of Foam-Free Superinsulation Details
There’s more than one way to build a highly insulated, air-tight house—or to tighten up and super-insulate an existing home. Here’s a look at an evolving array of superinsulated details that don’t use spray foam. More
Working With Roxul Insulation
Choosing insulation for a high-performance home in Northern Vermont requires... More
Reusing Loose-Fill Cellulose
Working around existing attic insulation to seal air leaks may be more cost-effective than removing and replacing it More
Fire Retardant in Spray Foam
Is it a potential health hazard? More
Can Fiberglass Batts Perform Well in Tightly Sealed Houses?
I understand that fiberglass batt insulation can allow air to move through it and that this air movement degrades the insulation's R-value. Two causes I've heard about are wind-washing at the eaves and convective loops that can start in a wall cavity on really cold days and wick warmth from inside to the outside wall surface. But recently I have taken pains to do a very good air-sealing job on everything I build, whether it's an addition or a new house. I'm getting blower-door readings of less than 1.5 air changes per hour at 50 pascals. I also use baffles at the eaves, and seal the sheathing to the framing before insulating. Under these conditions - with air movement cut to a minimum - will fiberglass insulation perform at its stated R-value? More
View All >
