Insulating Foundations
JLC Field Guide: Insulating Foundations
Below-grade heat loss can be significant in colder climates. And as with any structure in the ground, you also have pay close attention to water and moisture issues. But the marriage of moisture and insulation is not always a happy one.
Learn More
Insulating Foundations Featured Articles
Warmer, Drier Basements
Superior Wallsí XiPlus foundation panels have an insulation value of R-21 More
Insulated Foundation for an Urban Infill Site
JLC visits the Boston neighborhood of Jamaica Plain to see how Placetailor... More
Insulating Foundations Instruction
Calculating FPSF Insulation Requirements
There are two good sources for designing frost-protected shallow foundations (FPSFs). More
Q&A: Retrofitting a Walk-Out Basement
How do you protect the footing and foundation from frost in a very cold climate... More
Insulating Outside the Foundation
Best practices for insulating a foundation. More
Frost-Protected Shallow Garage Slab
Instead of excavating to below the frostline, insulate below the edge of the slab... More
Insulating Basement Walls
Q. I'm doing a basement remodel and am thinking of finishing the block foundation walls by painting the masonry with Drylok, then adhering 4-mil poly over that. Next, I plan to fur the walls with Z-studs, put 2 inches of foil-faced polyiso board between t More
View All >
