Insulation Materials
On Site with Roxul
On Site with Roxul
Hammer & Hand owner Sam Hagerman provides useful insights into the use of Roxul ... More
Insulating with Spray Cellulose
An insulation contractor explains why he prefers damp-spray cellulose for wall... More
Detailing a Superinsulated Slab
A less-expensive and energy-efficient foundation for a house More
Working With Thick Layers of Exterior Insulation
JLC editor Clayton DeKorne reviews the latest Department of Energy guidelines on... More
Island House Makeover — Insulating the Skin
In the teeth of a record-breaking winter, Thompson Johnson Woodworking wraps the... More
View All >
Insulation Materials Instruction
Creating a Palette of Foam-Free Superinsulation Details
There’s more than one way to build a highly insulated, air-tight house—or to tighten up and super-insulate an existing home. Here’s a look at an evolving array of superinsulated details that don’t use spray foam. More
Working With Roxul Insulation
Choosing insulation for a high-performance home in Northern Vermont requires... More
Reusing Loose-Fill Cellulose
Working around existing attic insulation to seal air leaks may be more cost-effective than removing and replacing it More
Fire Retardant in Spray Foam
Is it a potential health hazard? More
Attic Insulation for Hot Climates?
Q: Builders in cold climates often go beyond code-required attic insulation levels... More
View All >
