A.David Ballantyne, project engineer at Icynene, Inc., responds: The best way to patch a hole in Icynene insulation will depend on the size of the repair. For small and medium-sized patches, a can of spray urethane foam (one-component foam from the lumberyard or hardware store) works very well. There is no compatibility problem with using other foam insulation products directly against Icynene.
However, a large patch would require many cans of one-component foam, so it would be better repaired by installing more Icynene, or another two-component foam product applied by a professional applicator.
