A.David Utterback responds: When installing wood siding over rigid foam sheathing, you must protect the siding from moisture and heat buildup, and use proper nailing.
Moisture protection and heat buildup. Since foil-faced foam is a moisture barrier, it should be used with a continuous-film vapor retarder on the inside wall under the interior finish to keep condensation out of the wall cavity.
